Re: honda hobbit stocko shocko extremo 70cc kit
paul you're buying a spree head from me be careful not to overheat !
the notch in the piston is cut out for bikes which have decompression valves in their cylinder heads. like a honda hobbit =]
you can see the valve in the top of the head just barely. thats peters athena kit with some porting
the springy ring thing that they're talking about is an expansion ring to hold out the bottom ring. it goes in there under the bottom ring to push it against the cylinder
