Re: bigblockfiero new tech
Prairie dog wrote,
"Drilling holes behind the rings have been done for years too. Drag bikes used to use it. Similar idea to using a dykes ring piston, use the available pressure to force the rings against the walls to form a tighter seal."
If you read the stuffy crank thread you will understand that this is different.
"drag bikes used to do it." YES, FOUR STROKES, AND THEY STILL DO EVEN FOR MANY OTHER TYPES OF RACING. SHOW ME A PICK OF A SINGLE RING TWO STROKE WITH RINGLAND PORTS, NO SUCH THING.
"simular idea to using a dykes ring piston." SIMULAR IN ONE WAY BUT THE UPPER RING LAND DOESN"T LEAK UPWARD FLOW ON A DYKES RING PACK. READ STUFFY CRANK THREAD.
It is apparent that the very basic premis for this mod has been misunderstood and overlooked here.
