Re: bigblockfiero new tech
When it makes more power it makes more heat so yes it could run hotter. Your problem is something else tho like you said.
Running out of gas can cause a seize, really. Say the fuel line is restricted so the bowl starts to empty. air will pull right thru the main jet.
