Forums / Moped Performance
80cc puch hybrid
clay (clayy) — Oct 28, 2009 01:14AM
i know this isn't technically a moped, but it has moped parts. maybe you all won't boo me off of here.
anyways i started with a 66cc chinese bike motor that had reached the limits of the stock cylinder. which has a bore of 47 and a stroke of 40. so i found out the headbolt spacing was very close to a puch, BINGO! reeds and nikasil on the way. now my motor is smaller because the puch has a stroke of 43. the only thing i could do was stroke it, 10mm.....
i built the removeable balance pads out of aluminum to replace the cast iron ones that came stock. balanced the crank with brass slugs for a target rpm of 9000rpm (i hope 53% was right for 9k)
transfers and 7mm cylinder spacer
my port timing ended up being 176 on the exh and 132 or 136 on the transfers. since i dont have a centrifugal clutch my exh timing needs to be a little more conservative
lead in pipe is 10.75" with a 2deg taper. then 10" of 6deg taper. 3.25" of 12deg taper next. chamber is just under 3" dia and 5 inch long. the baffle cone will be 16 deg maybe (feedback on this point would be greatly appreciated)
carb is off a 110 4stroke pitbike. i believe you would call it a 22mm mikuni, but the venturi is oval shaped so i have no idea.
have i done anything extremely wrong?
  80cc puch hybrid clay 10/28/09 01:14AM
  Re: 80cc puch hybrid rofman 10/28/09 01:17AM
  Re: 80cc puch hybrid clay 10/28/09 01:23AM
  Re: 80cc puch hybrid clay 10/28/09 01:29AM
  Re: 80cc puch hybrid clay 10/28/09 01:31AM
  Re: 80cc puch hybrid ) Cupermcnewbster ( 10/28/09 01:33AM
  Re: 80cc puch hybrid Sunset Paul 10/28/09 01:36AM
  Re: 80cc puch hybrid Flagrant - 10/28/09 02:03AM
  Re: 80cc puch hybrid Flagrant - 10/28/09 02:09AM
  Re: 80cc puch hybrid jimmy 10/28/09 03:20AM
  Re: 80cc puch hybrid ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 10/28/09 04:33AM
  Re: 80cc puch hybrid clay 10/28/09 10:59AM
  Re: 80cc puch hybrid Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 10/28/09 11:55AM
  Re: 80cc puch hybrid mike 10/28/09 11:56AM
  Re: 80cc puch hybrid clay 10/28/09 04:36PM
  Re: 80cc puch hybrid octavio 10/28/09 02:36PM
  Re: 80cc puch hybrid Flagrant - 10/28/09 02:44PM
  Re: 80cc puch hybrid Grey L 10/28/09 03:21PM
  Re: 80cc puch hybrid Sunset Paul 10/28/09 06:22PM
  Re: 80cc puch hybrid clay 10/29/09 03:23AM
  Re: 80cc puch hybrid Sunset Paul 10/29/09 03:49AM
  Re: 80cc puch hybrid mattology - 10/29/09 04:14AM
  Re: 80cc puch hybrid Charlie BUZZARD 10/29/09 06:06AM
  Re: 80cc puch hybrid Graham Motzing 10/29/09 10:50AM
  Re: 80cc puch hybrid clay 10/29/09 11:29PM
  Re: 80cc puch hybrid Aidan 10/29/09 11:43PM
  Re: 80cc puch hybrid Flagrant - 10/30/09 12:04AM
  Re: 80cc puch hybrid clay 10/30/09 12:48AM
  Re: 80cc puch hybrid clayton 10/30/09 01:34AM
  Re: 80cc puch hybrid clay 10/30/09 10:44AM
  Re: 80cc puch hybrid vw4lifemi 10/30/09 12:43PM
  Re: 80cc puch hybrid zeke 10/30/09 01:17PM
  Re: 80cc puch hybrid coco 10/30/09 01:21PM
  Re: 80cc puch hybrid Flagrant - 10/30/09 03:49PM
  Re: 80cc puch hybrid benH 10/30/09 09:41PM
  Re: 80cc puch hybrid mattology - 10/31/09 01:42AM
  Re: 80cc puch hybrid Tate 10/31/09 01:56AM
  Re: 80cc puch hybrid mattology - 10/31/09 01:43PM
  Re: 80cc puch hybrid clay 10/31/09 01:48PM
  Re: 80cc puch hybrid coco 10/31/09 01:58PM
  Re: 80cc puch hybrid Sunset Paul 10/31/09 03:59PM
  Re: 80cc puch hybrid Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 10/31/09 06:46PM
  Re: 80cc puch hybrid kohis 11/02/09 04:52PM
  Re: 80cc puch hybrid Zerro 11/05/09 05:07PM
  Re: 80cc puch hybrid doppelkolben 11/05/09 05:24PM
  Re: 80cc puch hybrid Grey L 11/05/09 05:43PM
  Re: 80cc puch hybrid clay 11/07/09 06:30PM
  Re: 80cc puch hybrid ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/08/09 12:50AM
  Re: 80cc puch hybrid Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 11/08/09 01:36AM
  Re: 80cc puch hybrid clay 11/11/09 11:38PM
  Re: 80cc puch hybrid andrewhed 11/11/09 11:50PM
  Re: 80cc puch hybrid ) Cupermcnewbster ( 11/12/09 03:02AM
  Re: 80cc puch hybrid clay 11/12/09 02:47PM
  Re: 80cc puch hybrid doppelkolben 11/12/09 04:28PM
  Re: 80cc puch hybrid clay 11/12/09 11:15PM
  Re: 80cc puch hybrid bentokenone 11/13/09 02:04AM
  Re: 80cc puch hybrid ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/12/09 11:32PM
  Re: 80cc puch hybrid clay 11/13/09 12:45AM
  Re: 80cc puch hybrid ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/13/09 12:52AM
  Re: 80cc puch hybrid clayy 11/13/09 03:14PM
  Re: 80cc puch hybrid clay 01/04/10 06:39PM
  Re: 80cc puch hybrid ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 01/04/10 07:34PM
  Re: 80cc puch hybrid jack 01/04/10 08:25PM
  Re: 80cc puch hybrid Tate 01/05/10 12:14AM
  Re: 80cc puch hybrid clay 01/05/10 04:45PM
  Re: 80cc puch hybrid clay 01/06/10 12:06AM
  Re: 80cc puch hybrid GARzan Justin 01/06/10 12:44AM
  Re: 80cc puch hybrid GARzan Justin 01/06/10 12:45AM
  Re: 80cc puch hybrid ryandurepo 01/06/10 02:01AM
  Re: 80cc puch hybrid ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 01/06/10 02:11AM
  Re: 80cc puch hybrid Charlie BUZZARD 01/06/10 03:02AM
  Re: 80cc puch hybrid Magurczek 01/06/10 03:13AM
  Re: 80cc puch hybrid clay 01/06/10 11:33AM
  Re: 80cc puch hybrid Noob Saibot 01/06/10 12:35PM
  Re: 80cc puch hybrid maciek 01/06/10 10:11PM
  Re: 80cc puch hybrid Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 01/06/10 10:45PM
  Re: 80cc puch hybrid hotrodtodd 01/07/10 01:56PM
  Re: 80cc puch hybrid Cappy 01/07/10 08:56PM
  Re: 80cc puch hybrid Bacon 01/10/10 04:30AM
  Re: 80cc puch hybrid ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 07/08/10 07:57AM
  Re: 80cc puch hybrid Colinswoop . 07/08/10 10:15AM
Click here to login.
