Re: Batavus Performance Makeover
Jesse the long rod puts less stress on the wrist pin at higher RPM,s.
If the cylinder is shimmed up to mach the port timing of a stock rod length you get better top end to.
After i re-time the ports to mach RPM pipe carb & powerband it will rip it up!
Baja Mark
For Jetting with port mod's
Dellorto main jet's 116 114 112 110 108 106 104 102 100 98 .
Dellorto carburetor needle W7.
Dellorto PHBG carburetor idle jets 42 45 48.
Baja Mark
| Subject | Written By | Posted |
