Forums / Moped Performance
Re: Treats new Super Stuffy Crank
bigblockfiero (bigblockfiero) — Oct 08, 2009 11:10PM
Just guideline thoughts here,
(1) So you can't get away with raising transfers as much where the T-port is closer to the E-port but where the T-port is farther away then you can.
(2) Also: your transfer flow needs to flow close to the piston crown nearer to the x-port. Transfer flow can be more upward where the T-port is located farther from the E-port.
If the ceiling of a T-port window is tapered to satisfy the two above conditions then it doesn't flow well with all the mixture speed changes shifting crossways within the port. One wider transfer is often split into two smaller ones so that each can be different without effecting the other.
Cutting eyebrows off the back of the transfers gives an independant port design for 3mm of piston travel till the rest of the transfers open then - - - - - that 3mm shooter port becomes inactive and flow gets redirrected to flow closer to the piston crown as the window becomes more wide open. Dont debur the machining edges that would represent a transition from one port design (standard) to the next (eyebraw shooter barrel cut) because that would compromize the open windows flow ability to follow the piston crown and that sharp edge is neaded to help vaporize fuel. I did this wrong as pictured in that gofast story or rather I do it better now leaving sharp edges.
  Treats new Super Stuffy Crank Angry Bald Man 09/30/09 12:31PM
  Re: Treats new Super Stuffy Crank derek 09/30/09 01:02PM
  Re: Treats new Super Stuffy Crank Sunset Paul 09/30/09 02:10PM
  Re: Treats new Super Stuffy Crank [[ Linda ]] 09/30/09 03:06PM
  Re: Treats new Super Stuffy Crank Angry Bald Man 09/30/09 05:07PM
  Re: Treats new Super Stuffy Crank Chris Rice 09/30/09 07:27PM
  Re: Treats new Super Stuffy Crank bigblockfiero 09/30/09 09:42PM
  Re: Treats new Super Stuffy Crank [[ Linda ]] 09/30/09 06:40PM
  Re: Treats new Super Stuffy Crank Tate 09/30/09 09:25PM
  Re: Treats new Super Stuffy Crank jake 09/30/09 10:27PM
  Re: Treats new Super Stuffy Crank AirSoluble 09/30/09 10:45PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/01/09 01:14AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/01/09 01:17AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/01/09 01:32AM
  Re: Treats new Super Stuffy Crank Gabe Bandit 10/01/09 01:41AM
  Re: Treats new Super Stuffy Crank AirSoluble 10/01/09 06:21AM
  Re: Treats new Super Stuffy Crank SABAT! 10/01/09 03:23PM
  Re: Treats new Super Stuffy Crank Flagrant - 10/01/09 07:10PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/01/09 07:55PM
  Re: Treats new Super Stuffy Crank spencer 10/01/09 08:05PM
  Re: Treats new Super Stuffy Crank spencer 10/01/09 08:06PM
  Re: Treats new Super Stuffy Crank Mo Peds 10/01/09 08:41PM
  Re: Treats new Super Stuffy Crank spencer 10/01/09 09:04PM
  Re: Treats new Super Stuffy Crank ILIA 10/02/09 01:18AM
  Re: Treats new Super Stuffy Crank Gabe Bandit 10/02/09 01:20AM
  Re: Treats new Super Stuffy Crank timo 10/02/09 04:25PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/02/09 08:48PM
  Re: Treats new Super Stuffy Crank Mo Peds 10/02/09 09:26PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/02/09 10:03PM
  Re: Treats new Super Stuffy Crank Mo Peds 10/03/09 03:01AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/06/09 12:52AM
  Re: Treats new Super Stuffy Crank Mo Peds 10/06/09 11:42AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/08/09 12:35AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/08/09 12:51AM
  Re: Treats new Super Stuffy Crank ORFN omfg 10/27/09 07:18PM
  Re: Treats new Super Stuffy Crank ORFN omfg 10/27/09 07:30PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/27/09 08:46PM
  Re: Treats new Super Stuffy Crank spencer 10/03/09 12:37AM
  Re: Treats new Super Stuffy Crank Mo Peds 10/03/09 03:00AM
  Re: Treats new Super Stuffy Crank spencer 10/03/09 03:14AM
  Re: Treats new Super Stuffy Crank Mo Peds 10/03/09 03:20AM
  Re: Treats new Super Stuffy Crank coco 09/15/10 09:24PM
  Re: Treats new Super Stuffy Crank clayton 10/03/09 05:23AM
  Re: Treats new Super Stuffy Crank [[ Linda ]] 10/03/09 07:56PM
  Re: Treats new Super Stuffy Crank SABAT! 10/03/09 10:38PM
  Re: Treats new Super Stuffy Crank SABAT! 10/04/09 01:22AM
  Re: Treats new Super Stuffy Crank SABAT! 10/07/09 03:28AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/08/09 02:10AM
  Re: Treats new Super Stuffy Crank SABAT! 10/07/09 11:01AM
  Re: Treats new Super Stuffy Crank Max Mojo 10/07/09 06:42PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/08/09 01:17AM
  Re: Treats new Super Stuffy Crank Flagrant - 10/08/09 02:46AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/08/09 11:10PM
  Re: Treats new Super Stuffy Crank Max Mojo 10/08/09 11:43AM
  Re: Treats new Super Stuffy Crank Flagrant - 10/09/09 01:31AM
  Re: Treats new Super Stuffy Crank Sunset Paul 10/09/09 02:07AM
  Re: Treats new Super Stuffy Crank spencer 10/09/09 02:13AM
  Re: Treats new Super Stuffy Crank Mo Peds 10/09/09 09:44AM
  Re: Treats new Super Stuffy Crank ILIA 10/09/09 02:30PM
  Re: Treats new Super Stuffy Crank Sunset Paul 10/09/09 03:57PM
  Re: Treats new Super Stuffy Crank SABAT! 10/09/09 10:00PM
  Re: Treats new Super Stuffy Crank SABAT! 10/09/09 10:02PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/09/09 11:18PM
  Re: Treats new Super Stuffy Crank stronGAR 10/10/09 06:24PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/14/09 12:51AM
  Re: Treats new Super Stuffy Crank Flagrant - 10/10/09 07:14PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/14/09 01:04AM
  Re: Treats new Super Stuffy Crank Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 10/10/09 09:21PM
  Re: Treats new Super Stuffy Crank SABAT! 10/12/09 12:46AM
  Re: Treats new Super Stuffy Crank SABAT! 10/12/09 07:07PM
  Re: Treats new Super Stuffy Crank GR/NDER 10/14/09 01:11AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/14/09 01:21AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/14/09 01:35AM
  Re: Treats new Super Stuffy Crank GR/NDER 10/14/09 01:34AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/14/09 01:57AM
  Re: Treats new Super Stuffy Crank GR/NDER 10/14/09 03:13AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/14/09 03:30AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/14/09 03:39AM
  Re: Treats new Super Stuffy Crank GR/NDER 10/14/09 04:02AM
  Re: Treats new Super Stuffy Crank SABAT! 10/14/09 01:03PM
  Re: Treats new Super Stuffy Crank SABAT! 10/14/09 01:33PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/15/09 01:06AM
  Re: Treats new Super Stuffy Crank SABAT! 10/14/09 03:59PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/15/09 12:45AM
  Re: Treats new Super Stuffy Crank stronGAR 10/15/09 01:48AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/16/09 01:23AM
  Re: Treats new Super Stuffy Crank Mr.Frostback 10/15/09 02:25AM
  Re: Treats new Super Stuffy Crank GR/NDER 10/15/09 02:25AM
  Re: Treats new Super Stuffy Crank SABAT! 10/15/09 02:49AM
  Re: Treats new Super Stuffy Crank SABAT! 10/16/09 01:33AM
  Re: Treats new Super Stuffy Crank Mo Peds 10/16/09 10:39AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/16/09 08:33PM
  Re: Treats new Super Stuffy Crank GR/NDER 10/16/09 02:30AM
  Re: Treats new Super Stuffy Crank frick 10/16/09 09:48AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 10:56PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/27/09 11:27PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/28/09 08:23PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/29/09 10:14PM
  Re: Treats new Super Stuffy Crank stronGAR 10/16/09 04:07PM
  Re: Treats new Super Stuffy Crank frick 10/16/09 04:30PM
  Re: Treats new Super Stuffy Crank stronGAR 10/16/09 05:58PM
  Re: Treats new Super Stuffy Crank GR/NDER 10/16/09 06:23PM
  Re: Treats new Super Stuffy Crank Joe 10/16/09 06:56PM
  Re: Treats new Super Stuffy Crank SABAT! 10/16/09 09:20PM
  Re: Treats new Super Stuffy Crank Joe 10/16/09 11:16PM
  Re: Treats new Super Stuffy Crank GR/NDER 10/17/09 12:32AM
  Re: Treats new Super Stuffy Crank 6000 SUX 10/17/09 01:26PM
  Re: Treats new Super Stuffy Crank Zap Heteroped 10/17/09 01:57PM
  Re: Treats new Super Stuffy Crank Joe 10/19/09 01:37AM
  Re: Treats new Super Stuffy Crank Mr.Frostback 10/26/09 04:37PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/26/09 11:53PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/27/09 12:19AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 01:20AM
  Re: Treats new Super Stuffy Crank Mo Peds 10/27/09 01:37AM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/27/09 01:48AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 02:57AM
  Re: Piston-land ports Crazy Wayne Treats Rock's 10/27/09 04:32AM
  Re: Treats new Super Stuffy Crank [[ Linda ]] 10/26/09 11:08PM
  Re: Treats new Super Stuffy Crank Sunset Paul 10/27/09 01:32AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 01:40AM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/27/09 05:06PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 10:28PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 10:30PM
  Re: Treats new Super Stuffy Crank Mo Peds 10/27/09 01:39AM
  Re: Treats new Super Stuffy Crank Graham Motzing 10/27/09 02:36AM
  Re: Piston-land ports Sunset Paul 10/27/09 01:54PM
  Re: Piston-land ports bigblockfiero 10/27/09 10:09PM
  Re: Piston-land ports coco 10/27/09 02:14PM
  Re: Treats new Super Stuffy Crank Sunset Paul 10/27/09 05:56PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/27/09 08:31PM
  Re: Treats new Super Stuffy Crank 6000 SUX 10/27/09 09:55PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/27/09 10:13PM
  Re: Treats new Super Stuffy Crank 6000 SUX 10/27/09 10:02PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 10:14PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 10:58PM
  Re: Treats new Super Stuffy Crank .... 10/28/09 01:37AM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/28/09 03:02AM
  Re: Treats new Super Stuffy Crank Joe 10/28/09 02:21AM
  Re: Treats new Super Stuffy Crank Graham Motzing 10/28/09 05:09PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/28/09 08:30PM
  Re: Treats new Super Stuffy Crank coco 10/29/09 03:13PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/29/09 09:56PM
  Re: Treats new Super Stuffy Crank Joe 10/29/09 04:39PM
  Re: Treats new Super Stuffy Crank Sunset Paul 10/29/09 05:25PM
  Re: Treats new Super Stuffy Crank coco 10/29/09 05:40PM
  Re: Treats new Super Stuffy Crank coco 10/29/09 06:07PM
  Re: Treats new Super Stuffy Crank Flagrant - 10/29/09 06:24PM
  Re: Treats new Super Stuffy Crank Joe 10/29/09 06:25PM
  Re: Treats new Super Stuffy Crank Phrick 10/29/09 06:41PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/29/09 08:56PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/29/09 09:37PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/29/09 10:50PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/29/09 09:45PM
  Re: Treats new Super Stuffy Crank coco 10/29/09 10:14PM
  Re: Treats new Super Stuffy Crank Joe 10/29/09 11:08PM
  Re: Treats new Super Stuffy Crank coco 10/30/09 01:56AM
  Re: Treats new Super Stuffy Crank coco 10/30/09 02:03AM
  Re: Treats new Super Stuffy Crank Joe 10/30/09 02:20AM
  Re: Treats new Super Stuffy Crank ORFN omfg 10/30/09 08:42AM
  Re: Treats new Super Stuffy Crank SUNSET motobrokane 10/30/09 09:26AM
  Re: Treats new Super Stuffy Crank mattology - 11/02/09 03:38AM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/03/09 10:02PM
  Re: Treats new Super Stuffy Crank Graham Motzing 11/02/09 12:43PM
  Re: Treats new Super Stuffy Crank Josh B. 11/02/09 04:27PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/03/09 09:53PM
  Re: Treats new Super Stuffy Crank Josh B. 11/03/09 03:43AM
  Re: Treats new Super Stuffy Crank SABAT! 11/03/09 02:28PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/03/09 10:27PM
  Re: Treats new Super Stuffy Crank Matt 11/03/09 10:55PM
  Re: Treats new Super Stuffy Crank mattology - 11/03/09 02:44PM
  Re: Treats new Super Stuffy Crank Sunset Paul 11/03/09 02:52PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/03/09 10:34PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/03/09 10:37PM
  Re: Treats new Super Stuffy Crank Mo Peds 11/03/09 03:00PM
  Re: Treats new Super Stuffy Crank coco 11/03/09 11:20PM
  Re: Treats new Super Stuffy Crank Flagrant - 11/03/09 11:59PM
  Re: Treats new Super Stuffy Crank Jimmy Stucky 11/04/09 11:20AM
  Re: Treats new Super Stuffy Crank StronGAR 11/04/09 04:34PM
  Re: Treats new Super Stuffy Crank StronGAR 11/04/09 04:41PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/04/09 07:55PM
  Re: Treats new Super Stuffy Crank StronGAR 11/04/09 11:12PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/04/09 11:47PM
  Re: Treats new Super Stuffy Crank StronGAR 11/05/09 01:24AM
  Re: Treats new Super Stuffy Crank Rob @t ATTN! Burrito 11/05/09 01:07PM
  Re: Treats new Super Stuffy Crank Rob @t ATTN! Burrito 11/05/09 01:13PM
  Re: Treats new Super Stuffy Crank Rob @t ATTN! Burrito 11/05/09 01:25PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/06/09 02:52AM
  Re: Treats new Super Stuffy Crank mattology - 11/05/09 02:02PM
  Re: Treats new Super Stuffy Crank Flagrant - 11/05/09 03:40PM
  Re: Treats new Super Stuffy Crank Rufio 11/05/09 11:01PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/06/09 02:16AM
  Re: Treats new Super Stuffy Crank icallednotit 11/08/09 04:25AM
  Re: Treats new Super Stuffy Crank Johno 11/09/09 07:16AM
  Re: Treats new Super Stuffy Crank zeke 11/22/09 06:19AM
  Re: Treats new Super Stuffy Crank phrick 11/22/09 11:20PM
  Re: Treats new Super Stuffy Crank GR/NDER 11/28/09 10:36PM
  Re: Treats new Super Stuffy Crank Mo Peds 09/14/10 02:51PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 09/14/10 04:39PM
  Re: Treats new Super Stuffy Crank Mo Peds 09/14/10 04:50PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 09/14/10 05:39PM
  Re: Treats new Super Stuffy Crank Pavel 09/16/10 09:04PM
  Re: Treats new Super Stuffy Crank coco 09/16/10 11:24PM
  Re: Treats new Super Stuffy Crank clayy 09/17/10 01:33AM
  Re: Treats new Super Stuffy Crank Dan O 09/23/10 03:28PM
Click here to login.
