Forums / Moped Performance
Re: Treats new Super Stuffy Crank
bigblockfiero (bigblockfiero) — Sep 30, 2009 09:42PM
So the higher case pressure can send transfer mixture out the exhaust unless of course the relection wave from the pipe is strong enough by design to push the mixture back into the cylinder before the exhaust port closes.
A better solution is to use this extra available energy to your advantage. Lets assume your reflection wave isn't strong enough and mixture is escaping out the exhaust. What we need to do is use up some of the case pressure before the transfers open so that when they do, pressure isn't really any higher then if it wasn't stuffed.
We do this by running only one ring (the top) then putting ring land ports around it inside the upper ring land (someone post a pick). Some case pressure is bled off before the transfers open. This flow purges exhaust residuals from the ring pack and piston clearance volume so it can be sent out the exhaust on every stroke. In the process this flow effectively cools the piston sides all the way to the crown. You can then tune a more powerful, leaner mixture without worry of seizure. And lastly, the extra flow threw the ring pack is like adding some transfer window area, but without all the port timing compromises. I've got before and after dyno sheets if your interested.
  Treats new Super Stuffy Crank Angry Bald Man 09/30/09 12:31PM
  Re: Treats new Super Stuffy Crank derek 09/30/09 01:02PM
  Re: Treats new Super Stuffy Crank Sunset Paul 09/30/09 02:10PM
  Re: Treats new Super Stuffy Crank [[ Linda ]] 09/30/09 03:06PM
  Re: Treats new Super Stuffy Crank Angry Bald Man 09/30/09 05:07PM
  Re: Treats new Super Stuffy Crank Chris Rice 09/30/09 07:27PM
  Re: Treats new Super Stuffy Crank bigblockfiero 09/30/09 09:42PM
  Re: Treats new Super Stuffy Crank [[ Linda ]] 09/30/09 06:40PM
  Re: Treats new Super Stuffy Crank Tate 09/30/09 09:25PM
  Re: Treats new Super Stuffy Crank jake 09/30/09 10:27PM
  Re: Treats new Super Stuffy Crank AirSoluble 09/30/09 10:45PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/01/09 01:14AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/01/09 01:17AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/01/09 01:32AM
  Re: Treats new Super Stuffy Crank Gabe Bandit 10/01/09 01:41AM
  Re: Treats new Super Stuffy Crank AirSoluble 10/01/09 06:21AM
  Re: Treats new Super Stuffy Crank SABAT! 10/01/09 03:23PM
  Re: Treats new Super Stuffy Crank Flagrant - 10/01/09 07:10PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/01/09 07:55PM
  Re: Treats new Super Stuffy Crank spencer 10/01/09 08:05PM
  Re: Treats new Super Stuffy Crank spencer 10/01/09 08:06PM
  Re: Treats new Super Stuffy Crank Mo Peds 10/01/09 08:41PM
  Re: Treats new Super Stuffy Crank spencer 10/01/09 09:04PM
  Re: Treats new Super Stuffy Crank ILIA 10/02/09 01:18AM
  Re: Treats new Super Stuffy Crank Gabe Bandit 10/02/09 01:20AM
  Re: Treats new Super Stuffy Crank timo 10/02/09 04:25PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/02/09 08:48PM
  Re: Treats new Super Stuffy Crank Mo Peds 10/02/09 09:26PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/02/09 10:03PM
  Re: Treats new Super Stuffy Crank Mo Peds 10/03/09 03:01AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/06/09 12:52AM
  Re: Treats new Super Stuffy Crank Mo Peds 10/06/09 11:42AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/08/09 12:35AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/08/09 12:51AM
  Re: Treats new Super Stuffy Crank ORFN omfg 10/27/09 07:18PM
  Re: Treats new Super Stuffy Crank ORFN omfg 10/27/09 07:30PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/27/09 08:46PM
  Re: Treats new Super Stuffy Crank spencer 10/03/09 12:37AM
  Re: Treats new Super Stuffy Crank Mo Peds 10/03/09 03:00AM
  Re: Treats new Super Stuffy Crank spencer 10/03/09 03:14AM
  Re: Treats new Super Stuffy Crank Mo Peds 10/03/09 03:20AM
  Re: Treats new Super Stuffy Crank coco 09/15/10 09:24PM
  Re: Treats new Super Stuffy Crank clayton 10/03/09 05:23AM
  Re: Treats new Super Stuffy Crank [[ Linda ]] 10/03/09 07:56PM
  Re: Treats new Super Stuffy Crank SABAT! 10/03/09 10:38PM
  Re: Treats new Super Stuffy Crank SABAT! 10/04/09 01:22AM
  Re: Treats new Super Stuffy Crank SABAT! 10/07/09 03:28AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/08/09 02:10AM
  Re: Treats new Super Stuffy Crank SABAT! 10/07/09 11:01AM
  Re: Treats new Super Stuffy Crank Max Mojo 10/07/09 06:42PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/08/09 01:17AM
  Re: Treats new Super Stuffy Crank Flagrant - 10/08/09 02:46AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/08/09 11:10PM
  Re: Treats new Super Stuffy Crank Max Mojo 10/08/09 11:43AM
  Re: Treats new Super Stuffy Crank Flagrant - 10/09/09 01:31AM
  Re: Treats new Super Stuffy Crank Sunset Paul 10/09/09 02:07AM
  Re: Treats new Super Stuffy Crank spencer 10/09/09 02:13AM
  Re: Treats new Super Stuffy Crank Mo Peds 10/09/09 09:44AM
  Re: Treats new Super Stuffy Crank ILIA 10/09/09 02:30PM
  Re: Treats new Super Stuffy Crank Sunset Paul 10/09/09 03:57PM
  Re: Treats new Super Stuffy Crank SABAT! 10/09/09 10:00PM
  Re: Treats new Super Stuffy Crank SABAT! 10/09/09 10:02PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/09/09 11:18PM
  Re: Treats new Super Stuffy Crank stronGAR 10/10/09 06:24PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/14/09 12:51AM
  Re: Treats new Super Stuffy Crank Flagrant - 10/10/09 07:14PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/14/09 01:04AM
  Re: Treats new Super Stuffy Crank Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 10/10/09 09:21PM
  Re: Treats new Super Stuffy Crank SABAT! 10/12/09 12:46AM
  Re: Treats new Super Stuffy Crank SABAT! 10/12/09 07:07PM
  Re: Treats new Super Stuffy Crank GR/NDER 10/14/09 01:11AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/14/09 01:21AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/14/09 01:35AM
  Re: Treats new Super Stuffy Crank GR/NDER 10/14/09 01:34AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/14/09 01:57AM
  Re: Treats new Super Stuffy Crank GR/NDER 10/14/09 03:13AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/14/09 03:30AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/14/09 03:39AM
  Re: Treats new Super Stuffy Crank GR/NDER 10/14/09 04:02AM
  Re: Treats new Super Stuffy Crank SABAT! 10/14/09 01:03PM
  Re: Treats new Super Stuffy Crank SABAT! 10/14/09 01:33PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/15/09 01:06AM
  Re: Treats new Super Stuffy Crank SABAT! 10/14/09 03:59PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/15/09 12:45AM
  Re: Treats new Super Stuffy Crank stronGAR 10/15/09 01:48AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/16/09 01:23AM
  Re: Treats new Super Stuffy Crank Mr.Frostback 10/15/09 02:25AM
  Re: Treats new Super Stuffy Crank GR/NDER 10/15/09 02:25AM
  Re: Treats new Super Stuffy Crank SABAT! 10/15/09 02:49AM
  Re: Treats new Super Stuffy Crank SABAT! 10/16/09 01:33AM
  Re: Treats new Super Stuffy Crank Mo Peds 10/16/09 10:39AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/16/09 08:33PM
  Re: Treats new Super Stuffy Crank GR/NDER 10/16/09 02:30AM
  Re: Treats new Super Stuffy Crank frick 10/16/09 09:48AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 10:56PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/27/09 11:27PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/28/09 08:23PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/29/09 10:14PM
  Re: Treats new Super Stuffy Crank stronGAR 10/16/09 04:07PM
  Re: Treats new Super Stuffy Crank frick 10/16/09 04:30PM
  Re: Treats new Super Stuffy Crank stronGAR 10/16/09 05:58PM
  Re: Treats new Super Stuffy Crank GR/NDER 10/16/09 06:23PM
  Re: Treats new Super Stuffy Crank Joe 10/16/09 06:56PM
  Re: Treats new Super Stuffy Crank SABAT! 10/16/09 09:20PM
  Re: Treats new Super Stuffy Crank Joe 10/16/09 11:16PM
  Re: Treats new Super Stuffy Crank GR/NDER 10/17/09 12:32AM
  Re: Treats new Super Stuffy Crank 6000 SUX 10/17/09 01:26PM
  Re: Treats new Super Stuffy Crank Zap Heteroped 10/17/09 01:57PM
  Re: Treats new Super Stuffy Crank Joe 10/19/09 01:37AM
  Re: Treats new Super Stuffy Crank Mr.Frostback 10/26/09 04:37PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/26/09 11:53PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/27/09 12:19AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 01:20AM
  Re: Treats new Super Stuffy Crank Mo Peds 10/27/09 01:37AM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/27/09 01:48AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 02:57AM
  Re: Piston-land ports Crazy Wayne Treats Rock's 10/27/09 04:32AM
  Re: Treats new Super Stuffy Crank [[ Linda ]] 10/26/09 11:08PM
  Re: Treats new Super Stuffy Crank Sunset Paul 10/27/09 01:32AM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 01:40AM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/27/09 05:06PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 10:28PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 10:30PM
  Re: Treats new Super Stuffy Crank Mo Peds 10/27/09 01:39AM
  Re: Treats new Super Stuffy Crank Graham Motzing 10/27/09 02:36AM
  Re: Piston-land ports Sunset Paul 10/27/09 01:54PM
  Re: Piston-land ports bigblockfiero 10/27/09 10:09PM
  Re: Piston-land ports coco 10/27/09 02:14PM
  Re: Treats new Super Stuffy Crank Sunset Paul 10/27/09 05:56PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/27/09 08:31PM
  Re: Treats new Super Stuffy Crank 6000 SUX 10/27/09 09:55PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/27/09 10:13PM
  Re: Treats new Super Stuffy Crank 6000 SUX 10/27/09 10:02PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 10:14PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/27/09 10:58PM
  Re: Treats new Super Stuffy Crank .... 10/28/09 01:37AM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 10/28/09 03:02AM
  Re: Treats new Super Stuffy Crank Joe 10/28/09 02:21AM
  Re: Treats new Super Stuffy Crank Graham Motzing 10/28/09 05:09PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/28/09 08:30PM
  Re: Treats new Super Stuffy Crank coco 10/29/09 03:13PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/29/09 09:56PM
  Re: Treats new Super Stuffy Crank Joe 10/29/09 04:39PM
  Re: Treats new Super Stuffy Crank Sunset Paul 10/29/09 05:25PM
  Re: Treats new Super Stuffy Crank coco 10/29/09 05:40PM
  Re: Treats new Super Stuffy Crank coco 10/29/09 06:07PM
  Re: Treats new Super Stuffy Crank Flagrant - 10/29/09 06:24PM
  Re: Treats new Super Stuffy Crank Joe 10/29/09 06:25PM
  Re: Treats new Super Stuffy Crank Phrick 10/29/09 06:41PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/29/09 08:56PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/29/09 09:37PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/29/09 10:50PM
  Re: Treats new Super Stuffy Crank bigblockfiero 10/29/09 09:45PM
  Re: Treats new Super Stuffy Crank coco 10/29/09 10:14PM
  Re: Treats new Super Stuffy Crank Joe 10/29/09 11:08PM
  Re: Treats new Super Stuffy Crank coco 10/30/09 01:56AM
  Re: Treats new Super Stuffy Crank coco 10/30/09 02:03AM
  Re: Treats new Super Stuffy Crank Joe 10/30/09 02:20AM
  Re: Treats new Super Stuffy Crank ORFN omfg 10/30/09 08:42AM
  Re: Treats new Super Stuffy Crank SUNSET motobrokane 10/30/09 09:26AM
  Re: Treats new Super Stuffy Crank mattology - 11/02/09 03:38AM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/03/09 10:02PM
  Re: Treats new Super Stuffy Crank Graham Motzing 11/02/09 12:43PM
  Re: Treats new Super Stuffy Crank Josh B. 11/02/09 04:27PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/03/09 09:53PM
  Re: Treats new Super Stuffy Crank Josh B. 11/03/09 03:43AM
  Re: Treats new Super Stuffy Crank SABAT! 11/03/09 02:28PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/03/09 10:27PM
  Re: Treats new Super Stuffy Crank Matt 11/03/09 10:55PM
  Re: Treats new Super Stuffy Crank mattology - 11/03/09 02:44PM
  Re: Treats new Super Stuffy Crank Sunset Paul 11/03/09 02:52PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/03/09 10:34PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/03/09 10:37PM
  Re: Treats new Super Stuffy Crank Mo Peds 11/03/09 03:00PM
  Re: Treats new Super Stuffy Crank coco 11/03/09 11:20PM
  Re: Treats new Super Stuffy Crank Flagrant - 11/03/09 11:59PM
  Re: Treats new Super Stuffy Crank Jimmy Stucky 11/04/09 11:20AM
  Re: Treats new Super Stuffy Crank StronGAR 11/04/09 04:34PM
  Re: Treats new Super Stuffy Crank StronGAR 11/04/09 04:41PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/04/09 07:55PM
  Re: Treats new Super Stuffy Crank StronGAR 11/04/09 11:12PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/04/09 11:47PM
  Re: Treats new Super Stuffy Crank StronGAR 11/05/09 01:24AM
  Re: Treats new Super Stuffy Crank Rob @t ATTN! Burrito 11/05/09 01:07PM
  Re: Treats new Super Stuffy Crank Rob @t ATTN! Burrito 11/05/09 01:13PM
  Re: Treats new Super Stuffy Crank Rob @t ATTN! Burrito 11/05/09 01:25PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/06/09 02:52AM
  Re: Treats new Super Stuffy Crank mattology - 11/05/09 02:02PM
  Re: Treats new Super Stuffy Crank Flagrant - 11/05/09 03:40PM
  Re: Treats new Super Stuffy Crank Rufio 11/05/09 11:01PM
  Re: Treats new Super Stuffy Crank bigblockfiero 11/06/09 02:16AM
  Re: Treats new Super Stuffy Crank icallednotit 11/08/09 04:25AM
  Re: Treats new Super Stuffy Crank Johno 11/09/09 07:16AM
  Re: Treats new Super Stuffy Crank zeke 11/22/09 06:19AM
  Re: Treats new Super Stuffy Crank phrick 11/22/09 11:20PM
  Re: Treats new Super Stuffy Crank GR/NDER 11/28/09 10:36PM
  Re: Treats new Super Stuffy Crank Mo Peds 09/14/10 02:51PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 09/14/10 04:39PM
  Re: Treats new Super Stuffy Crank Mo Peds 09/14/10 04:50PM
  Re: Treats new Super Stuffy Crank Crazy Wayne Treats Rock's 09/14/10 05:39PM
  Re: Treats new Super Stuffy Crank Pavel 09/16/10 09:04PM
  Re: Treats new Super Stuffy Crank coco 09/16/10 11:24PM
  Re: Treats new Super Stuffy Crank clayy 09/17/10 01:33AM
  Re: Treats new Super Stuffy Crank Dan O 09/23/10 03:28PM
Click here to login.
