Proma Exhaust on Honda Express
http://www.treatland.tv/honda-hobbit-proma-performance-pipe-p/honda-proma-pipe-hobbit-pa50.htm
Has anyone put one of these on a HONDA Nc50? I am trying to figure out what to modify to make the pipe fit. There seems to be three points where clearance is any issue. The rear tire is the first and a little grinding with the dremmel should take care of that. The second is with the pipe and the bottom fins of the cylinder head. Should I trim the fins or modify the pipe for clearance. The third pinch point is the with the cross bar that stretches between the foot pegs. Has anyone modified the frame or should i cut and weld in a channel to all for the clearance. Let me know you guys think? Is cutting into the exhaust a good idea? Will that have a drastic effect on performance?
http://s1008.photobucket.com/albums/af202/szytec/exhaust/
