Re: maxi dies when I open the throttle up.
sounds like you've bent your float into a position that doesn't allow th bowl to fill all the way. Try reving while tapping the 'flood' button on the side of your carb. If it runs better, you need to bend your float back to where it was.
| Subject | Written By | Posted |
