Forums / Moped Performance
Re: trick to installing moby oil seals
steve (stevep1989) — Jul 05, 2009 09:48AM
i dunno ive had a real hard time before as well, i think there might be a couple different moby sizes and sometimes you just get the wrong ones. with a little heat, a nickel, screwdriver butt and some tapping they usually slide right in. but i had one set that would NOT go in, seemingly because it was too large.
  trick to installing moby oil seals jaym 07/04/09 02:58AM
  Re: trick to installing moby oil seals Andy 07/04/09 03:10AM
  Re: trick to installing moby oil seals jaym 07/04/09 03:15AM
  Re: trick to installing moby oil seals Jesse -B 07/04/09 09:58AM
  Re: trick to installing moby oil seals Mike Recker 07/04/09 10:49AM
  Re: trick to installing moby oil seals jaym 07/04/09 11:50AM
  Re: trick to installing moby oil seals Mike Recker 07/04/09 03:48PM
  Re: trick to installing moby oil seals Mr.Frostback 07/04/09 05:52PM
  Re: trick to installing moby oil seals Flagrant - 07/04/09 06:22PM
  Re: trick to installing moby oil seals seniorita gato 07/05/09 02:16AM
  Re: trick to installing moby oil seals jaym 07/05/09 07:34AM
  Re: trick to installing moby oil seals PAULVOLIO 07/05/09 09:38AM
  Re: trick to installing moby oil seals steve 07/05/09 09:48AM
  Re: trick to installing moby oil seals Mike Recker 07/05/09 11:13AM
  Re: trick to installing moby oil seals peter 07/05/09 02:23PM
  Re: trick to installing moby oil seals Jesse Stephenson 07/05/09 03:35PM
  Re: trick to installing moby oil seals Erik 07/05/09 10:15PM
  Re: trick to installing moby oil seals jaym 07/05/09 10:56PM
  Re: trick to installing moby oil seals Ryan B 07/05/09 11:18PM
  Re: trick to installing moby oil seals jaym 07/05/09 11:36PM
  Re: trick to installing moby oil seals Mike Recker 07/06/09 12:03AM
  Re: trick to installing moby oil seals jaym 07/06/09 12:14AM
  Re: trick to installing moby oil seals Mike Recker 07/06/09 08:22AM
  Re: trick to installing moby oil seals Kelin 07/08/09 10:57PM
  Re: trick to installing moby oil seals Ryan B 07/09/09 04:02PM
  Re: trick to installing moby oil seals jaym 07/10/09 10:21PM
Click here to login.
