Re: WoT sporatic bog
Sounds like fuel delivery or an airleak.
check float bowl for functionality.
drill a hole in your gas cap.
open up the petcock a bit.
if applicable make sure your fuel filter is flowing well...
It's always good to go back and re-set your points and clean them, Wierd problems always seem to back to the electrical system, no matter how convinced I am it's a fuel delivery issue.
other possibility is that you may have play in your crank, which can cause airleaks at high RPM.
I dunno, there's alot it could be! good luck!
| Subject | Written By | Posted |
