Re: PHBG knockoff jet sizes.
The stock ones are huge, I did the same, I soldered the idle ad main then drilled them intentionally too small. then I will work them up till too big, then back to last good size (I know this is sorta backwards). I'm still having problems, mids still too lean despite needle being way up. Hmmm.
Question, does needle go thru the plastic thingy as well as slide?
Runs great with choke on :-)
| Subject | Written By | Posted |
