Forums / Moped Performance
qt50 adjustable timeing mod
Alex Tribeck (ryanc) — Jul 03, 2009 06:03AM
Those bolts used to be rivets I drilled the rivet out, tapped the hub side and elongated the holes in the flywheel. Apparently not elongated enough to show I'll take the bolts out and snap another picture tomorrow. I suspect I only elongated them enough for 5degrees advance but it's slightly noticeable at low rpm. You can barely see the marks I put in it both pieces just left of the nut.
  qt50 adjustable timeing mod Alex Tribeck 07/03/09 06:03AM
  Re: qt50 adjustable timeing mod mauvescorpion 07/03/09 03:02PM
  Re: qt50 adjustable timeing mod ryan 07/03/09 05:40PM
  Re: qt50 adjustable timeing mod matt76 07/03/09 11:42PM
  Re: qt50 adjustable timeing mod Ryan 07/04/09 09:18PM
Click here to login.
