Forums / Moped Performance
Re: top end for case inducted E50
Octavio (el_pollo_diablo) — Jul 03, 2009 03:10PM
I built a case inducted e50 It's working great! I used a 4petal polini reedblock. It fit perfectly over the crank. Also, I used JBweld to build up the needed pad to mount the reedbock on. Just be mindful that you have to build up some material but not so much that the carb interferes with the bottom of your frame. Also, I used a 70cc kstar for my cylinder, but that's only because I'm a cheepo. If you go the cash, go big!
  top end for case inducted E50 spencer 07/02/09 02:35AM
  Re: top end for case inducted E50 DarthNater 07/02/09 02:46AM
  Re: top end for case inducted E50 spencer 07/02/09 03:01AM
  Re: top end for case inducted E50 spencer 07/18/09 11:57PM
  Re: top end for case inducted E50 spencer 07/03/09 12:29AM
  Re: top end for case inducted E50 robby 07/03/09 03:44AM
  Re: top end for case inducted E50 vic 07/03/09 06:43AM
  Re: top end for case inducted E50 vic 07/03/09 06:44AM
  Re: top end for case inducted E50 human drew 07/03/09 10:48AM
  Re: top end for case inducted E50 spencer 07/03/09 12:20PM
  Re: top end for case inducted E50 Octavio 07/03/09 03:10PM
  Re: top end for case inducted E50 Octavio 07/03/09 03:16PM
  Re: top end for case inducted E50 ezdasnowman!! 07/19/09 12:43AM
  Re: top end for case inducted E50 bowie82 11/09/10 12:43AM
  Re: top end for case inducted E50 spencer 07/19/09 09:13PM
  Re: top end for case inducted E50 Jesse -B 03/09/10 10:43AM
  Re: top end for case inducted E50 L V 03/09/10 05:20PM
  Re: top end for case inducted E50 spencer 03/09/10 05:39PM
  Re: top end for case inducted E50 logan cain 03/09/10 07:23PM
  Re: top end for case inducted E50 spencer 03/09/10 07:34PM
  Re: top end for case inducted E50 Octavio 03/09/10 11:28PM
  Re: top end for case inducted E50 Los Dean 03/09/10 11:46PM
  Re: top end for case inducted E50 bryan 03/09/10 11:52PM
  Re: top end for case inducted E50 Not Tate 03/09/10 11:53PM
  Re: top end for case inducted E50 Not Tate 03/09/10 11:59PM
  Re: top end for case inducted E50 rock finally shredding pow 03/10/10 12:03AM
  Re: top end for case inducted E50 Octavio 03/10/10 12:11AM
  Re: top end for case inducted E50 Octavio 03/10/10 12:14AM
  Re: top end for case inducted E50 Octavio 03/10/10 12:15AM
  Re: top end for case inducted E50 spencer 03/10/10 12:17AM
  Re: top end for case inducted E50 spencer 03/10/10 12:19AM
  Re: top end for case inducted E50 mattology - 03/10/10 01:30AM
  Re: top end for case inducted E50 clay 03/10/10 12:41PM
  Re: top end for case inducted E50 clay 03/10/10 12:50PM
  Re: top end for case inducted E50 clay 03/10/10 12:51PM
  Re: top end for case inducted E50 Dream 11/10/10 10:02PM
  Re: top end for case inducted E50 clay 11/10/10 11:58PM
  Re: top end for case inducted E50 Elliott 11/11/10 12:59AM
  Re: top end for case inducted E50 Will campeona del mundo Caldwell 11/11/10 01:10AM
  Re: top end for case inducted E50 bowie82 11/13/10 12:04PM
Click here to login.
