Re: Dirtbike forks..
I've been using YZ80 forks for awhile . Any KX80 YZ80 CR80 etc uses a 17" x 1.4" rim in the form of a drum or disk configuration . I used a couple diskbrake setups in the pass and they work great - Complete fork bolt-on to a general frame OR Use just the tubes to a modded General tree . Bearings are either roller or loose balls . Here's a pic of YZ80 forktubes on a General 5-Star tree 26mm with 1mm shims and modded for snowflakes . BTW rear shocks are CB125 . whole bike is 3 inches taller for a neighbor.
| Subject | Written By | Posted |
