Re: Dirtbike forks..
I have found the stem on pitbike forks (the ones with the tiny front wheel) is about 2 inches too short to mount up to a bike. I had to trim the steering tube on mine down a bit and mill about an inch out of various components (top and bottom triple tree plate, bearing races), looks like it will work but the motor is still in process.
the 14inch tire and rim is less then 2 inches shorter in overall height then a 16inch rim and tire as that front tire is pretty beefy
| Subject | Written By | Posted |
