Forums / Moped Performance
Kit break in guide
SamRM ( samm) — Jul 01, 2009 12:07PM
Heres a break in guide that a friend passed on to me... I thought I would share.
1. Start your engine, let it idle, and check for air leaks. once
none remain move to step 2.
2. Start your engine and let it idle, occasionally blipping the
throttle for four to five minutes. Allow the engine to
cool completely. Repeat this heat cycle process four more times.
3. Warm up the engine again and ride the bike for five to seven minutes at a very easy pace. Vary the rpm, and do
not ride at one speed. Do not ride at more that 1/3 throttle or more than 1/3 rpm. Let the engine cool down
completely and repeat this initial break in ride. Let the engine cool down.
4. Check the head nuts for proper torque.
5. Ride the bike for five to ten minutes at a moderate pace. Vary the rpm, and do not ride at more than 3/4 throttle
or more than 3/4 rpm. Then let the engine cool completely and repeat this secondary break-in twice more.
6. Replace the spark plug with a new one. Ride the bike for five to eight minutes at a moderate pace. Vary the rpm. Once the engine is up to operating temperature, you can make a jetting pass. Ride at a moderate/high rpm. With the throttle wide open hold the kill button down and stop.
7. Read the spark plug. With a pocket flashlight and a magnifying glass, look at the porcelain Palt of the plug
only. As you view the plug from the center electrode, look down on the length of the porcelain to its base.
There should be a dark chocolate colored smoke ring. There was not sufficient time to thoroughly color the whole plug, so the nose of the insulator may still be white. As long
as there is a visible dark ring at the base, everything is OK. Remember, we want break-in jetting, so the plug
should read rich/dark. Richen the jetting as necessary. If you are having a hard time reading the spark plug, follow the proceeding steps: Put the plug in a vice, and hacksaw around the plug at the washer. Break the threads off with vise grips and the porcelain will be easy to read.
8. Complete the break-in by riding at an aggressive pace for fifteen minutes. Vary the rpm and do not cruise at part throttle. Ride hard without revving the engine too high. At the end of this final break-in session do another jetting pass/plug chop as described above. Check the spark plug for the correct dark/rich condition.
9. Replace the spark plug with a new one. Ride the bike aggressively for eight minutes and do a jetting pass/plug chop at full rpm. If the porcelain color is still dark/rich, lean the main jet size one at a time until the smoke ring at the base of the porcelain is a light brown. If the porcelain base is white, do not run the engine, check for air leaks, and jet size. If the plug color looks good, continue riding at a race pace for ten minutes. Stop and let the engine cool. Check the torque on the cylinder base and head nuts.
  Kit break in guide SamRM 07/01/09 12:07PM
  Re: Kit break in guide Erin L 07/01/09 12:46PM
  Re: Kit break in guide SamRM 07/01/09 02:45PM
  Re: Kit break in guide Bad Adam 07/01/09 02:40PM
  Re: Kit break in guide JoshuaBlackBlack 07/01/09 03:05PM
  Re: Kit break in guide Baltard Drought 07/01/09 03:12PM
  Re: Kit break in guide SamRM 07/01/09 03:44PM
  Re: Kit break in guide [[ Linda ]] 07/02/09 02:20AM
  Re: Kit break in guide —— ¢hief —— 07/01/09 05:21PM
  Re: Kit break in guide Capt Howdy 07/01/09 05:31PM
  Re: Kit break in guide smoking bear 07/01/09 05:32PM
  Re: Kit break in guide Rob Farmer 07/02/09 01:24PM
  Re: Kit break in guide Dirty Dave Stone 07/02/09 10:10PM
  Re: Kit break in guide AllTheRuss 07/06/09 01:05AM
  Re: Kit break in guide Metrakittens 07/06/09 06:05AM
  Re: Kit break in guide Pipe Burn 01/10/11 05:20AM
  Re: Kit break in guide Zeke 01/10/11 11:12AM
  Re: Kit break in guide seniorita 01/10/11 11:22AM
  Re: Kit break in guide Graham Motzing 01/10/11 01:43PM
  Re: Kit break in guide Matt Mahloch -- MBM Customs 01/10/11 07:28PM
  Re: Kit break in guide pbone 01/10/11 10:06PM
  Re: Kit break in guide Ryan N. 01/11/11 12:46AM
  Re: Kit break in guide Max Mojo 01/11/11 01:22AM
  Re: Kit break in guide maciek 01/11/11 07:48PM
  Re: Kit break in guide Roffman 01/12/11 03:28PM
  Re: Kit break in guide HonkyCat 01/13/11 01:15PM
  Re: Kit break in guide HonkyCat 01/13/11 01:22PM
  Re: Kit break in guide Aron 01/13/11 01:22PM
  Re: Kit break in guide Matt Mahloch -- MBM Customs 01/13/11 01:48PM
  Re: Kit break in guide Ƽɧ▲ɴƹ β 01/13/11 01:58PM
  Re: Kit break in guide HonkyCat 01/13/11 02:38PM
  Re: Kit break in guide Matt Mahloch -- MBM Customs 01/13/11 02:44PM
  Re: Kit break in guide jOHNNY dOUBE⟴ 01/13/11 03:09PM
  Re: Kit break in guide Graham Motzing 01/14/11 12:34PM
Click here to login.
