Forums / Moped Performance
Re: sachs performance
Mike Bartell ( mikebartell) — Jul 03, 2009 11:00PM
Also if you didn't know, the gianelli pipe for sachs will crack on you. I just welded mine up for the second time. I had it mounted so the entire weight was on the motor, no connection to the frame and welded in a support to close the spiral. It still cracked. You can see in the picture- the hole in the larger side is where the support was.
When I can afford it, I'll get something else, but until then, I'm going with a spring mount on the front, and a rubber block form a muffler shop for the rear. Without re-gearing on the athena reed valve kit, at 11 front 45 rear, I'm hitting 40, and doing it fast.
I actually would love to re-gear, and get a low end pipe.
  sachs performance nick 06/26/09 01:15AM
  Re: sachs performance nerdzilla Ripset 06/26/09 10:25AM
  Re: sachs performance Mike Recker 06/26/09 03:16PM
  Re: sachs performance nick 06/27/09 12:11AM
  Re: sachs performance Robert 06/27/09 12:13AM
  Re: sachs performance Josh 06/30/09 05:49PM
  Re: sachs performance Los Dean 06/27/09 01:09AM
  Re: sachs performance nerdzilla Ripset 07/03/09 04:12PM
  Re: sachs performance nerdzilla Ripset 06/27/09 08:40AM
  Re: sachs performance Mo Peds 06/27/09 10:20AM
  Re: sachs performance Robert 06/27/09 10:51AM
  Re: sachs performance Los Dean 06/27/09 02:27PM
  Re: sachs performance Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 06/27/09 08:41PM
  Re: sachs performance Mo Peds 06/27/09 08:44PM
  Re: sachs performance nerdzilla Ripset 06/28/09 02:03AM
  Re: sachs performance Mo Peds 06/28/09 03:06AM
  Re: sachs performance Mo Peds 06/28/09 03:07AM
  Re: sachs performance Robert 06/28/09 10:12AM
  Re: sachs performance Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 06/28/09 10:17AM
  Re: sachs performance nerdzilla Ripset 06/28/09 10:36AM
  Re: sachs performance Mo Peds 06/28/09 02:41PM
  Re: sachs performance tracy 07/04/09 01:49PM
  Re: sachs performance Mike Bartell 06/28/09 02:39PM
  Re: sachs performance Mike Bartell 06/28/09 03:11PM
  Re: sachs performance Mike Bartell 06/28/09 03:19PM
  Re: sachs performance Mike Bartell 06/28/09 03:20PM
  Re: sachs performance nerdzilla Ripset 06/28/09 09:41PM
  Re: sachs performance nerdzilla Ripset 06/29/09 12:35AM
  Re: sachs performance Mike Bartell 06/29/09 01:40AM
  Re: sachs performance Tate 06/29/09 01:58AM
  Re: sachs performance Mo Peds 06/29/09 02:32AM
  Re: sachs performance Mo Peds 06/29/09 02:33AM
  Re: sachs performance AirSoluble 06/29/09 07:14AM
  Re: sachs performance nerdzilla Ripset 06/29/09 01:09PM
  Re: sachs performance Mark 06/29/09 01:55PM
  Re: sachs performance ffreddie 06/29/09 03:30PM
  Re: sachs performance Los Dean 06/29/09 08:34PM
  Re: sachs performance Mike Bartell 06/29/09 11:48PM
  Re: sachs performance Los Dean 07/03/09 05:10PM
  Re: sachs performance Mike Bartell 07/03/09 11:00PM
  Re: sachs performance Aaron Blair 07/03/09 11:59PM
  Re: sachs performance AirSoluble 07/04/09 05:47AM
  Re: sachs performance Los Dean 07/04/09 06:26AM
  Re: sachs performance nerdzilla Ripset 07/04/09 08:52AM
  Re: sachs performance Mike Bartell 07/04/09 03:26PM
  Re: sachs performance nerdzilla Ripset 07/04/09 09:44PM
  Re: sachs performance Los Dean 07/05/09 02:25AM
  Re: sachs performance Mike Bartell 07/05/09 01:00PM
  Re: sachs performance Los Dean 07/05/09 05:01PM
  Re: sachs performance Mo Peds 07/05/09 06:13PM
  Re: sachs performance Los Dean 07/05/09 06:19PM
  Re: sachs performance Mo Peds 07/05/09 08:04PM
  Re: sachs performance Mike Bartell 07/05/09 06:22PM
  Re: sachs performance jarrett 07/05/09 08:15PM
  Re: sachs performance dylan 07/05/09 08:34PM
  Re: sachs performance los77 07/05/09 08:46PM
  Re: sachs performance Mo Peds 07/05/09 08:47PM
  Re: sachs performance Los Dean 07/05/09 09:09PM
  Re: sachs performance Mo Peds 07/05/09 09:51PM
  Re: sachs performance los77 07/05/09 11:01PM
  Re: sachs performance Los Dean 07/06/09 02:45AM
  Re: sachs performance nickels 07/06/09 03:27AM
  Re: sachs performance Los Dean 07/06/09 04:44AM
  Re: sachs performance los77 07/06/09 10:30AM
  Re: sachs performance Los Dean 07/06/09 02:52PM
  Re: sachs performance Josh 07/07/09 11:36AM
  Re: sachs performance Mo Peds 07/07/09 12:17PM
  Re: sachs performance Robert Rosselit 07/07/09 12:26PM
  Re: sachs performance nerdzilla Ripset 07/07/09 04:23PM
  Re: sachs performance nerdzilla Ripset 07/07/09 04:25PM
  Re: sachs performance Los Dean 07/07/09 05:20PM
  Re: sachs performance Robert Rosselit 07/07/09 06:11PM
  Re: sachs performance Los Dean 07/07/09 07:37PM
  Re: sachs performance Robert Rosselit 07/08/09 01:26PM
  Re: sachs performance Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 07/24/09 01:32PM
  Re: sachs performance Los Dean 07/24/09 04:06PM
  Re: sachs performance Tate 07/24/09 04:42PM
  Re: sachs performance Los Dean 07/24/09 04:46PM
Click here to login.
