Forums / Moped Performance
Ok, stock, ported, 19mm dell, 40, what now?
fubar (fubarman) — Jun 10, 2009 06:05AM
Ok, so I here's what I got:
e50, stock cyl.
14x40, I like some lo end ya know. Could be taller with more hp.
Biturdbo
Intake opened about 2mm per side. lowered 1mm, cham.
Exhaust opened like 3mm /side. raised 1mm, cham.
Dell Phbg spigot 19 clone, 72 jet. Needle lowest position (clip highest)
KN UFO style air filter, came with carb
Intake is about 5.5 in. (not counting spigot) and even dia. through. Was trying to keep it lo-vol. as possible, for more intake velocity.
3 shoe clutch, balanced/tuned and set to slip. No nifty springs.
40 mph, maybe a bit more when I do fine tuning on carb.
All the shit matches.
Hi comp head, and decent compression.
B6 plug
Stock crank
Not much $
High altitude
200 Lb rider (I'm 6'6", so there :-)
I have not done anything with the transfers or piston skirts, and the port window changes improved things (it seems). Carb still needs fine tuning.
Ports are about as big as I'd like to venture. What do I do with xfers piston and case? Port time changes seemed to help +rpm +hp, was I just stoned? Was I crazy to mess with this?
Good, and runs great, but some get that out of lots less mods. Much better than when I started I can say that!
What next? Xfers + case? Piston? Want more all around HP, Bit more speed for mixed city riding, and smoking yuppie scooters.
Thanks MA!
  Ok, stock, ported, 19mm dell, 40, what now? fubar 06/10/09 06:05AM
  Re: Ok, stock, ported, 19mm dell, 40, what now? Chris Hernandez 06/10/09 06:21AM
  Re: Ok, stock, ported, 19mm dell, 40, what now? fubar 06/11/09 01:58AM
  Re: Ok, stock, ported, 19mm dell, 40, what now? rockles 06/11/09 02:53AM
  Re: Ok, stock, ported, 19mm dell, 40, what now? Kansas John 06/11/09 11:05AM
  Re: Ok, stock, ported, 19mm dell, 40, what now? justin turner 06/11/09 01:33PM
  Re: Ok, stock, ported, 19mm dell, 40, what now? fubar 06/11/09 07:04PM
  Re: Ok, stock, ported, 19mm dell, 40, what now? Mo Peds 06/11/09 07:11PM
  Re: Ok, stock, ported, 19mm dell, 40, what now? Tyson 06/11/09 02:04PM
  Re: Ok, stock, ported, 19mm dell, 40, what now? fubar 06/14/09 03:46AM
  Re: Ok, stock, ported, 19mm dell, 40, what now? fubar 06/14/09 03:57AM
  Re: Ok, stock, ported, 19mm dell, 40, what now? fubar 06/15/09 10:03PM
  PICS! fubar 06/15/09 10:04PM
  Re: PICS! fubar 06/15/09 10:06PM
  Re: PICS! fubar 06/15/09 10:08PM
  Re: PICS! fubar 06/15/09 10:11PM
  Re: Ok, stock, ported, 19mm dell, 40, what now? fubar 06/15/09 10:28PM
  Re: Ok, stock, ported, 19mm dell, 40, what now? fubar 06/16/09 05:35AM
  Re: Ok, stock, ported, 19mm dell, 40, what now? Sunset Paul 06/16/09 06:41AM
  Re: Ok, stock, ported, 19mm dell, 40, what now? Matt Garrison 06/16/09 09:52AM
  Re: Ok, stock, ported, 19mm dell, 40, what now? fubar 06/16/09 10:45AM
  Re: Ok, stock, ported, 19mm dell, 40, what now? fubar 06/18/09 03:57AM
  Re: Ok, stock, ported, 19mm dell, 40, what now? fubar 06/18/09 10:27AM
  Re: Ok, stock, ported, 19mm dell, 40, what now? ∴ Μ Λ Ι Ζ Σ ∴ 06/18/09 11:01AM
  Re: Ok, stock, ported, 19mm dell, 40, what now? fubar 06/18/09 07:54PM
  Re: Ok, stock, ported, 19mm dell, 40, what now? ezdasnowGAR! 06/18/09 08:06PM
  Re: Ok, stock, ported, 19mm dell, 40, what now? fubar 06/18/09 10:10PM
  Re: Ok, stock, ported, 19mm dell, 40, what now? fubar 06/19/09 12:03AM
  Re: Ok, stock, ported, 19mm dell, 40, what now? Ben Van Zoest 06/19/09 04:41PM
  Re: Ok, stock, ported, 19mm dell, 40, what now? fubarman 06/23/09 03:02AM
  Update. fubarman 06/23/09 04:04AM
  Re: Update. /////////// 06/23/09 04:24AM
  Re: Update. Tyson 07/02/09 11:34AM
Click here to login.
