Re: Vespa Athena kits
I'm looking for a Tomos or Minarelli pipe with around a 25mm header which mounts on the right hand side that will hopefully fit on a ciao. see pic for header visuals.
As for the intake, I'm thinking this will fit on the ciao with little modification to the frame.
I took out the crappy exhaust studs and am going for allens, also had to grind down part of the flywheel case section for a potential exhaust to fit around the bolts.
