Re: Motobecane builds, post your mods!
^ I have one in progress that is identical to that except no clutch pulley and it has a different head. Aaron, you proposed setup is solid but you will not/cannot use reeds if it's an av7 (off american mobys). The av10 is the reed valve, case inducted euro version that people are referring to. The parma kit, 21 phbg, and ninja piper shouls shred hard. You will also need a new throttle assembly to open that throttle slide all the way. If you wanna explore the evil world of the AV10....go to the bank, make a huge withdrawal, and do tons of searches in the performance forum. Good luck.
