Forums / Moped Performance
Re: Motobecane builds, post your mods!
Elliot ( elliot) — May 12, 2009 01:30PM
the BEST build using readily available parts:
polini av10 larger reed block cases ported to match top end
mallossi 70cc av10 top end ported for better flow
mallossi av10 head with decomp
doppler endurance crank
doppler er3 variator running 4 heavy weights only
doppler clutch pulley with heavier springs
doppler engine tension spring 90% out
doppler pipe mounted on a ninja rear bracket
mallossi aka "ducati" CDI set to 22 degrees advanced from the mark
dellorto PHBG 21mm jetting: 96 main, 50 pilot, 7 needle all lean no filter
gearing 11 x 48
gates ax30 belt
B8HS
91 octane @ 50:1
  Motobecane builds, post your mods! Aaron S 05/12/09 10:55AM
  Re: Motobecane builds, post your mods! Crackstar X 05/12/09 11:13AM
  Re: Motobecane builds, post your mods! Aaron S 05/12/09 11:21AM
  Re: Motobecane builds, post your mods! Aimlessanduseless@sbcglobal.net 05/12/09 11:53AM
  Re: Motobecane builds, post your mods! Jesse -B 05/12/09 12:06PM
  Re: Motobecane builds, post your mods! Elliot 05/12/09 01:30PM
  Re: Motobecane builds, post your mods! motobee 05/12/09 02:23PM
  Re: Motobecane builds, post your mods! finny 05/12/09 06:34PM
  Re: Motobecane builds, post your mods! mipark56 05/12/09 06:43PM
  Re: Motobecane builds, post your mods! Shay D 05/13/09 01:13AM
  Re: Motobecane builds, post your mods! mipark56 05/13/09 02:40AM
  Re: Motobecane builds, post your mods! finny 05/13/09 03:02AM
  Re: Motobecane builds, post your mods! ) Cupermcnewbster ( 05/13/09 04:01AM
  Re: Motobecane builds, post your mods! davey 05/13/09 04:12AM
  Re: Motobecane builds, post your mods! mipark56 05/13/09 04:15AM
  Re: Motobecane builds, post your mods! mipark56 05/13/09 04:33AM
  Re: Motobecane builds, post your mods! Shay D 05/13/09 01:25PM
  Re: Motobecane builds, post your mods! Jesse Stephenson 05/13/09 05:36PM
  Re: Motobecane builds, post your mods! Mick Baltards 05/13/09 04:00PM
  Re: Motobecane builds, post your mods! mipark56 05/13/09 04:01PM
  Re: Motobecane builds, post your mods! Shay D 05/13/09 04:30PM
  Re: Motobecane builds, post your mods! ffreddie 05/13/09 04:32PM
  Re: Motobecane builds, post your mods! Elliot 05/13/09 04:38PM
  Re: Motobecane builds, post your mods! Ian T 05/13/09 05:24PM
  Re: Motobecane builds, post your mods! Tracy 05/13/09 05:58PM
  Re: Motobecane builds, post your mods! Shay D 05/13/09 06:07PM
  Re: Motobecane builds, post your mods! PAULVOLIO 05/13/09 07:51PM
  Re: Motobecane builds, post your mods! Elliot 05/13/09 11:50PM
  Re: Motobecane builds, post your mods! Sir Bolo Thaddeus 07/03/09 04:54AM
  Re: Motobecane builds, post your mods! nick 07/03/09 09:35PM
  Re: Motobecane builds, post your mods! Mike Alanko 07/03/09 10:27PM
  Re: Motobecane builds, post your mods! Mike Recker 07/04/09 10:53AM
  Re: Motobecane builds, post your mods! finny 07/04/09 01:38PM
  Re: Motobecane builds, post your mods! Jesse Stephenson 07/04/09 02:40PM
  Re: Motobecane builds, post your mods! Jesse -B 07/04/09 02:50PM
  Re: Motobecane builds, post your mods! Jesse Stephenson 07/04/09 06:20PM
  Re: Motobecane builds, post your mods! seniorita gato 07/04/09 07:20PM
  Re: Motobecane builds, post your mods! ∴ Μ Λ Ι Ζ Σ ∴ 07/04/09 09:02PM
  Re: Motobecane builds, post your mods! finny 07/05/09 01:33PM
Click here to login.
