Re: vespa owners: belt compliaton thread
Bravo = carquest belt 6841.
put on multivar, pulled engine all the way forward, belt slips the same as stock belt. slip = can't start with stock spring, only starts occasionally with yellow spring.
pulled engine all the way back, put on belt 6840 (1 inch shorter), belt doesn't slip, but can't fully variate up on the cheeks. I need to dremel the mounting holes a little forward to run the 6841 (but then pedals will hit the estoril pipe silencer) or backwards to use the 6840 to full potential.
