Forums / Moped Performance
Re: Jetting again - up to 52 - ALMOST DONE
Mitch (dumbcity) — Aug 09, 2006 01:00PM
Order from Mopedwarehouse.com. Cheaper jets, cheaper shipping. I've had multiple problems with 1977. No problems with Mopedwarehouse.
I don't thinkt he performance airfilter is worth it in this application. Probably not necessary unless I went to a bigger carb and exhaust. I'm guessing that if you replaced the screens in the stock airbox with coarse the foam material, it would be the same thing. Tough to tell though. I'll shoot the foam tonight and send you a pic.
That came out too wrong to even think about changing...
I don't think I'll be switching up to the 13/13 carb. This bike (The Shreadbest(TM)) can't handle these streets at higher speeds than where I'm at now -- but maybe I'm just a pussy. If I was on the well groomed streets of the real 'burbs or out on the long straights of the country I would. But not here on the cramped, pocked, and angry streets of the psuedo-city-suburbs.
So are you upjetting without a new exhaust? Let me know how that goes.
:M
  Sito Plus on Bravo mitch 07/06/06 11:12PM
  Re: Sito Plus on Bravo Russ 07/07/06 09:27PM
  Re: Sito Plus on Bravo mitch 07/09/06 06:45PM
  Plug Color + High Pitched Hum + Peal Arms Mitch 07/10/06 05:20PM
  Re: Plug Color + High Pitched Hum + Pedal Arms Mitch 07/25/06 09:49AM
  Plug Color + Temp Update Mitch 08/03/06 11:18PM
  Re: Plug Color + Temp Update Mitch 08/07/06 11:37PM
  'Sito Plus' Spec Sheet Mitch 07/10/06 05:21PM
  Jetting and Airflow Mitch 07/25/06 10:18AM
  Airflow Updates + Weight Mitch 07/31/06 10:09AM
  Project Cost Update Mitch 07/31/06 12:58PM
  Jetting again - up to 52 - ALMOST DONE Mitch 08/09/06 11:40AM
  Sito Plus on Bravo Sam 07/31/06 12:30PM
  Re: Sito Plus on Bravo Ben Kay 07/31/06 03:44PM
  Re: Sito Plus on Bravo Edward Edwards 07/31/06 06:12PM
  Re: Sito Plus on Bravo Jon 08/01/06 05:51PM
  Bravo Updated Pic Mitch 07/31/06 09:38PM
  Re: Bravo Updated Pic Sam 08/01/06 10:23AM
  Re: Sito Plus on Bravo Edward Edwards 08/02/06 08:55AM
  HOW TO FIND A SITO PLUS Mitch 08/03/06 11:20AM
  LEOVINCI CONTACT INFO Mitch 08/08/06 01:53PM
  MY DISCLAIMER, PLEASE READ Mitch 08/08/06 02:05PM
  Oops. Post order issue. Mitch 08/07/06 11:41PM
  Re: Oops. Post order issue. Colinswoop . 08/08/06 08:24AM
  Re: Oops. Post order issue. Colinswoop . 08/08/06 08:28AM
  Re: Jetting again - up to 52 - ALMOST DONE Sam 08/09/06 12:02PM
  Re: Jetting again - up to 52 - ALMOST DONE Mitch 08/09/06 01:00PM
  Re: Jetting again - up to 52 - ALMOST DONE Colinswoop . 08/09/06 01:31PM
  Re: Jetting again - up to 52 - ALMOST DONE Mitch 08/09/06 01:37PM
  Re: Jetting again - up to 52 - ALMOST DONE Colinswoop . 08/09/06 01:41PM
  Re: Jetting again - up to 52 - ALMOST DONE Mitch 08/09/06 01:45PM
  FINAL -- Jetted to 52+ -- FINAL Mitch 08/11/06 09:56AM
  Re: FINAL -- Jetted to 52+ -- FINAL Tyson 10/03/07 09:01PM
  Re: FINAL -- Jetted to 52+ -- FINAL Sam 08/14/06 01:37PM
  Re: FINAL -- Jetted to 52+ -- FINAL Mitch 08/14/06 06:07PM
  where to find this exhaust - two more places maciek 10/02/07 03:23AM
Click here to login.
