Forums / Moped Performance
Airflow Updates + Weight
Mitch (dumbcity) — Jul 31, 2006 10:09AM
Corrections:
The Poloni High Airflow Performace Air Filter actually did fit perfectly on my stock carb. It was the O-Ring Clamp that came with it that would not tighten enough to keep the box on tight. I used my stock O-Ring Clamp and now it's fine.
Once I switched from the stock air box to the Poloni after upjetting, I lost some performance. So I thought that maybe the Poloni wasn't as high-flow as it was supposed to be. It is built with 3 air holes, so I drileld two more. I also did a couple of other things in the process, so when I went for a ride and performance was worse, I wasn't sure what to blame it on. So I went home and drilled 2 more holes in the box. The bike idled fine, but I had no power. So then I went ahead and taped up all of my drilled holes, plus one of the originals (probably taking it back to stock box airflow levels) and performace and top speed were right back up.
The bike runs perfectly now at top speeds of 31/32mph on flats. I no longer have to pedal or push and swerve while trying to balance when accelerating from a stop.
Most rapid acceleration is in the midrange. It takes a little while to get up to max speed.
I have a long Moby seat on it right now, which is way to big for the bike, but so comfortable I can't take it off; The new shocks I put on are twice the wieght of the stock ones; my new pedals are probably heavier than the originals; and the Sito pipe is definitely heavier than the original -- so I've added a lot of weight to the bike. I guess I could knock a bunch of it off.. but I'm not racing this thing, and I like everything I've added, so it's worth the 1mph I might be losing because of it.
Now that I know I have extra air available at the intake side, maybe next I'll see if I can continue to upjet and see what I can squeeze out of this Sito. Even though I'm perfectly happy with 31/32mph top speeds, now I'm kind of curious.
:M
  Sito Plus on Bravo mitch 07/06/06 11:12PM
  Re: Sito Plus on Bravo Russ 07/07/06 09:27PM
  Re: Sito Plus on Bravo mitch 07/09/06 06:45PM
  Plug Color + High Pitched Hum + Peal Arms Mitch 07/10/06 05:20PM
  Re: Plug Color + High Pitched Hum + Pedal Arms Mitch 07/25/06 09:49AM
  Plug Color + Temp Update Mitch 08/03/06 11:18PM
  Re: Plug Color + Temp Update Mitch 08/07/06 11:37PM
  'Sito Plus' Spec Sheet Mitch 07/10/06 05:21PM
  Jetting and Airflow Mitch 07/25/06 10:18AM
  Airflow Updates + Weight Mitch 07/31/06 10:09AM
  Project Cost Update Mitch 07/31/06 12:58PM
  Jetting again - up to 52 - ALMOST DONE Mitch 08/09/06 11:40AM
  Sito Plus on Bravo Sam 07/31/06 12:30PM
  Re: Sito Plus on Bravo Ben Kay 07/31/06 03:44PM
  Re: Sito Plus on Bravo Edward Edwards 07/31/06 06:12PM
  Re: Sito Plus on Bravo Jon 08/01/06 05:51PM
  Bravo Updated Pic Mitch 07/31/06 09:38PM
  Re: Bravo Updated Pic Sam 08/01/06 10:23AM
  Re: Sito Plus on Bravo Edward Edwards 08/02/06 08:55AM
  HOW TO FIND A SITO PLUS Mitch 08/03/06 11:20AM
  LEOVINCI CONTACT INFO Mitch 08/08/06 01:53PM
  MY DISCLAIMER, PLEASE READ Mitch 08/08/06 02:05PM
  Oops. Post order issue. Mitch 08/07/06 11:41PM
  Re: Oops. Post order issue. Colinswoop . 08/08/06 08:24AM
  Re: Oops. Post order issue. Colinswoop . 08/08/06 08:28AM
  Re: Jetting again - up to 52 - ALMOST DONE Sam 08/09/06 12:02PM
  Re: Jetting again - up to 52 - ALMOST DONE Mitch 08/09/06 01:00PM
  Re: Jetting again - up to 52 - ALMOST DONE Colinswoop . 08/09/06 01:31PM
  Re: Jetting again - up to 52 - ALMOST DONE Mitch 08/09/06 01:37PM
  Re: Jetting again - up to 52 - ALMOST DONE Colinswoop . 08/09/06 01:41PM
  Re: Jetting again - up to 52 - ALMOST DONE Mitch 08/09/06 01:45PM
  FINAL -- Jetted to 52+ -- FINAL Mitch 08/11/06 09:56AM
  Re: FINAL -- Jetted to 52+ -- FINAL Tyson 10/03/07 09:01PM
  Re: FINAL -- Jetted to 52+ -- FINAL Sam 08/14/06 01:37PM
  Re: FINAL -- Jetted to 52+ -- FINAL Mitch 08/14/06 06:07PM
  where to find this exhaust - two more places maciek 10/02/07 03:23AM
Click here to login.
