Forums / Moped Performance
Sito Plus on Bravo
mitch (dumbcity) — Jul 06, 2006 11:12PM
I just put a Sito Plus exhaust on my Bravo with a stock 12/10 carb. I was able to find more questions than answers on this forum, and I'll probably have a lot myself, but I thought I'd add this to the forum for anyone else that is looking for info on it.
The Sito exhaust looks just like the stock exhaust, but the neck is fatter, and the body is fatter and about 3 or 4 inches longer. The Sito is about twice as heavy as the Stock. The mounting bracket that attaches to the frame is about 2" to the rear of the original. There's a photo attached here.
To mount the Sito, you'll have to drill a hole in the side panel to match up with the mounting bracket. Make the hole a little bit long, so that you have some back and forth adjustment when attaching it to the exhaust port.
Since the Sito is fatter, your right pedal is going to hit it. I've heard the same thing is true on a Ciao. I haven't solved this one yet. I might try to bang out the pedal arm an eigth to a quarter of an inch rather than looking for shorter pedal arms.
So far I haven't done any jetting or air adjustments. Obviously this will be a big part of it, but I haven't gotten there yet.
Without any adjustments to the stock setup, I have an improved mid range and top end, not so sure about the low end. It's really nice to be getting some more power out of my 25mph Bravo. Right now on a starightaway I'm hitting about 30mph. It's difficult to tell, as my speedo needle bobs up and down a lot.
I'm going to try to determine whether I can leave it as is without burning too rich or too lean. If it's fine as is, this will be a great, easy solution for anyone looking for a little more power with little work. If it does not burn correctly as is, I'll try to find the easiest solution and post it here.
From there I'll see if I can get more power by increasing jet size and air flow, and post all of that info here.
:Mitch
  Sito Plus on Bravo mitch 07/06/06 11:12PM
  Re: Sito Plus on Bravo Russ 07/07/06 09:27PM
  Re: Sito Plus on Bravo mitch 07/09/06 06:45PM
  Plug Color + High Pitched Hum + Peal Arms Mitch 07/10/06 05:20PM
  Re: Plug Color + High Pitched Hum + Pedal Arms Mitch 07/25/06 09:49AM
  Plug Color + Temp Update Mitch 08/03/06 11:18PM
  Re: Plug Color + Temp Update Mitch 08/07/06 11:37PM
  'Sito Plus' Spec Sheet Mitch 07/10/06 05:21PM
  Jetting and Airflow Mitch 07/25/06 10:18AM
  Airflow Updates + Weight Mitch 07/31/06 10:09AM
  Project Cost Update Mitch 07/31/06 12:58PM
  Jetting again - up to 52 - ALMOST DONE Mitch 08/09/06 11:40AM
  Sito Plus on Bravo Sam 07/31/06 12:30PM
  Re: Sito Plus on Bravo Ben Kay 07/31/06 03:44PM
  Re: Sito Plus on Bravo Edward Edwards 07/31/06 06:12PM
  Re: Sito Plus on Bravo Jon 08/01/06 05:51PM
  Bravo Updated Pic Mitch 07/31/06 09:38PM
  Re: Bravo Updated Pic Sam 08/01/06 10:23AM
  Re: Sito Plus on Bravo Edward Edwards 08/02/06 08:55AM
  HOW TO FIND A SITO PLUS Mitch 08/03/06 11:20AM
  LEOVINCI CONTACT INFO Mitch 08/08/06 01:53PM
  MY DISCLAIMER, PLEASE READ Mitch 08/08/06 02:05PM
  Oops. Post order issue. Mitch 08/07/06 11:41PM
  Re: Oops. Post order issue. Colinswoop . 08/08/06 08:24AM
  Re: Oops. Post order issue. Colinswoop . 08/08/06 08:28AM
  Re: Jetting again - up to 52 - ALMOST DONE Sam 08/09/06 12:02PM
  Re: Jetting again - up to 52 - ALMOST DONE Mitch 08/09/06 01:00PM
  Re: Jetting again - up to 52 - ALMOST DONE Colinswoop . 08/09/06 01:31PM
  Re: Jetting again - up to 52 - ALMOST DONE Mitch 08/09/06 01:37PM
  Re: Jetting again - up to 52 - ALMOST DONE Colinswoop . 08/09/06 01:41PM
  Re: Jetting again - up to 52 - ALMOST DONE Mitch 08/09/06 01:45PM
  FINAL -- Jetted to 52+ -- FINAL Mitch 08/11/06 09:56AM
  Re: FINAL -- Jetted to 52+ -- FINAL Tyson 10/03/07 09:01PM
  Re: FINAL -- Jetted to 52+ -- FINAL Sam 08/14/06 01:37PM
  Re: FINAL -- Jetted to 52+ -- FINAL Mitch 08/14/06 06:07PM
  where to find this exhaust - two more places maciek 10/02/07 03:23AM
Click here to login.
