Forums / Moped Repair
Re: NU50 problems help
Adam Kollipara (adam_1295) — Aug 09, 2010 02:07PM
NO, the auto choke SHOULD have fuel in the fuel lines, but only in 2 of them. The vacuum sucks the gas through them.
Here's the "1982 Honda Urban Express Shop Manual":http://www.mopedriders.org/html/manuals/honda/uexpress/huexpresssm.htm if you need it.
Tube 3 has only air. Tube 2 has the gas/oil mixture coming from the carb. Tube 1 has gas/oil mixture coming from tube 2 going into the engine to be used.
When starting cold, the bimetal strip should be bent so that the valve inside the black plastic connector (you can't see this) is blocking tube 3 from letting air in. This will create the rich mixture to start it cold. When it warms up, the bimetal bends so that it will let more air to keep in running (it doesn't need the rich mixture). Once the engine reaches about 150 degrees F, the auto choke shouldn't have to do anything. The bimetal strip will be bent to let air go through the valve only, blocking tube 2 from letting any gas/oil in, and the engine will use the gas/oil directly mixed from the carb.
Here's some pages from the "'77 - '81 Honda Express Shop Manual":http://www.mopedriders.org/html/manuals/honda/express/hexpresssm.htm showing how the auto choke works.
!http://www.mopedriders.org/html/manuals/honda/express/hexpresssm31-04.jpg!
!http://www.mopedriders.org/html/manuals/honda/express/hexpresssm31-05.jpg!
To see if the auto choke isn't working (the air is usually the problem, and I'm having this same problem), put you finger over the inlet to tube 3 in the bystarter. Start the engine and see if it keeps running. I had to do this and it worked. Th problem is that the bimetal strip isn't working to block the inlet to tube 3 when starting cold. Try putting a little plastic inline fuel shut off valve in tube 3 to see if this solves the problem. When starting cold, turn the valve to OFF and when it warms up, turn it to ON.
!http://lh3.ggpht.com/_q6VnRZ2wyys/S2HgjLHB1wI/AAAAAAAABwE/ufyOvUgS4Qk/B%26S%20Shutoff%20valve.jpg!
I hope this all helps.
~Adam
  NU50 problems help zach 08/08/10 12:36AM
  Re: NU50 problems help Bryan Keeley 08/08/10 04:31PM
  Re: NU50 problems help Chris . 08/08/10 06:38PM
  Re: NU50 problems help zach 08/09/10 12:07AM
  Re: NU50 problems help Rick 08/09/10 12:32PM
  Re: NU50 problems help Adam Kollipara 08/09/10 02:07PM
  Re: NU50 problems help zach 08/10/10 12:10AM
  Re: NU50 problems help Adam Kollipara 08/10/10 10:55AM
  Re: NU50 problems help Adam Kollipara 08/10/10 11:04AM
  Re: NU50 problems help Adam Kollipara 08/10/10 02:49PM
  Re: NU50 problems help zach 08/12/10 08:38PM
  Re: NU50 problems help zach 08/13/10 12:48AM
  Re: NU50 problems help Adam Kollipara 08/13/10 10:39PM
  Re: NU50 problems help Rusty Bikes 08/14/10 11:19AM
  Re: NU50 problems help zach 08/14/10 02:03PM
  Re: NU50 problems help Chris . 08/14/10 05:35PM
  Re: NU50 problems help zach 08/15/10 12:39AM
  Re: NU50 problems help zach 08/17/10 11:51AM
  Re: NU50 problems help Adam Kollipara 08/17/10 01:40PM
  Re: NU50 problems help zach 08/18/10 01:11AM
Click here to login.
