Forums / Moped Repair
Rebuilt motor - crank seems stuck...
DCrippa (dcrippa) — Nov 07, 2009 11:42AM
So I've rebuilt my A3 motor - I've had a ton of trouble pressing things out/ in, apart / together - as I don't have a hydrolic press... I ended up using some wood and c-clamps plus pullers to do everything I needed to do... I tried the bolt suggestion that someone mentioned to pull the cases together - and ended up snapping the bolt! Anyway.... problem is now that I've pressed the side case on I think I've either tightened the gear bolt too much or the screwed something up in reassembly like the orientation of the break spring - because now the crank shaft seems stuck. I haven't tried to put the fly wheel on - because now I'm thinking I have to open it up again.
One other question I had was does the break spring on the pedal shaft get oriented pointing to the back /up or forward in the little cut-out between the crankcase...
If anyone has any idea's as to what the problem could be or have come across this type of issue please chime in!
Click here to login.
