Forums / Moped Repair
Re: Rear Wheel Won't Turn
Brandon Eliason ( brandon) — Nov 07, 2009 07:31PM
The chain may be broken with the remains binding on the rear sprocket. It's underneath the long swing arm cover that the kick start sticks out of. another possibility is that the brake shoe linings have separated from the brake shoes and are jammed between the shoes and hub. Those are the first things I'd check for, aside from the brake cable being too tight.
  Rear Wheel Won't Turn Shane McKinney 11/07/09 05:42AM
  Re: Rear Wheel Won't Turn -Unholysmokers- Ben 11/07/09 10:28AM
  Re: Rear Wheel Won't Turn Josh Schutz 11/07/09 02:17PM
  Re: Rear Wheel Won't Turn circle 11/07/09 02:21PM
  Re: Rear Wheel Won't Turn Josh Schutz 11/07/09 04:13PM
  Re: Rear Wheel Won't Turn Shane McKinney 11/07/09 04:26PM
  Re: Rear Wheel Won't Turn Brandon Eliason 11/07/09 07:31PM
Click here to login.
