Forums / Moped Repair
tomos intermitten spark
Chance Johns ( chance) — Nov 06, 2009 06:30PM
i re wired my tomos now it has intermitten spark at high rpm's,i think
it ran fine before i re wired it. i did a better job then before and used a thicker gauge wire.
at high rpm's it stutter's i thought it could be fuel starvation but the stutter is so abrupt,i belive it is spark.
my ground wire on the external coil(cdi) has some exposed wire that might be banging around,but is definately attatched to a good ground.
i have it wired like so :
magneto to killswitch then back to coil.
i used 14 gauge wire instead of 16 or 18 stock wire.
i used splice terminals that were meant for a smaller gauge wire. maybe they didnt cut all the way thru for my grounds or ignition?
  tomos intermitten spark Chance Johns 11/06/09 06:30PM
  Re: tomos intermitten spark Chance Johns 11/06/09 06:35PM
Click here to login.
