Re: smoking tomos Arrow (oil injected)
Could be your crank seals, then again it could be the check valve at the injector banjo leaking down injector oil at a heavy rate. White smoke is usually trans fluid burning though. Check your fluid levels! Have a real look at the haze colour and what is dribbling out the pipe from excess.
| Subject | Written By | Posted |
