Forums / Moped Repair
Re: Moped won't turn over.
[[ Linda ]] (mycider) — Nov 04, 2009 04:16PM
First you have to figure out what's wrong, and then you have to fix what's wrong. Start with the easy stuff -- is your fuel on? Is your kill switch set to "run"? If both of those are good, take out your spark plug and test for spark. If you have spark, clean your carb. If you don't have spark, clean your points.
There's more info on all of this here.
  Moped won't turn over. Evan Micheels 11/04/09 01:58PM
  Re: Moped won't turn over. [[ Linda ]] 11/04/09 04:16PM
  Re: Moped won't turn over. keller_stephen 11/05/09 02:48AM
  Re: Moped won't turn over. jOHNNYdOUBE 11/05/09 08:57AM
  Re: Moped won't turn over. TIEDIE20 11/06/09 10:09PM
  Re: Moped won't turn over. vw4lifemi 11/05/09 10:37AM
  Re: Moped won't turn over. keller_stephen 11/06/09 10:19PM
  Re: Moped won't turn over. Evan Micheels 11/09/09 05:06PM
  Re: Moped won't turn over. Evan Micheels 11/09/09 05:07PM
Click here to login.
