Re: Garelli NOI clutch doesn't engage?
Plate #9, with all the holes in it, slides up and down over the cush bushings (#11). If they were melted, they would keep the plate from pushing the clutch rubber against the bell. There is a possibility that the bushings you had were not original and had been replaced by a material that dissolved from exposure to oil. Make sure you use fuel-safe tubing when you make replacements.
