Re: Garelli NOI clutch doesn't engage?
no its definitely not the cable, i just put a totally new one on. and i mean when i unhook the cable and just use my hands to push the start lever back, i seriously have to press as hard as i can with both hands and only sometimes it catches. im pretty sure thats not normal. when i hook the cable back up again and pull the clutch lever on the handlebars nothing happens. its not too loose, i adjusted it properly, i think somethings either fucked with the actual clutch or i need to add fluid. a mechanic i know said that if theres no fluid in there it might not work because the fluid creates the pressure thats needed or something. i dont know. i havent tried it yet though because i lost a spring in the clutch and need a new one before i can put it back together. but if thats not it then i have no idea whats wrong
and thats what i thought about the oil, i was just double checking, thanks.
