Forums / Moped Repair
Re: 84 Honda Aero 125 Scooter
Ken Martin (iamyhwh) — Oct 05, 2005 07:09PM
Hello to all. I own a 1984 Honda Aero 125, and have owned it for several years. I am blessed to have a "master mechanic" that attends my church who is very good at fixing what ails my little gold baby.
Here's a few things I've learned about this particular scooter:
It uses (rather, "drinks") oil, so make sure to keep the receptacle filled at all times! I use Honda 2 stroke oil that's specifically made for this usage.
I always use the highest octane gas available - usually 93 octane. It runs better!
It has a wierd electric choke mechanism called a "Bystarter" choke. If you want, I have info. about this and could attach it to a future message. Suffice it to say that it controls the choke by using engine heat. If you have trouble with your scooter running well, it very well could be this!
If you have trouble starting your scooter, remember to press down on the "foot" brake (right side floor panel) hard when pressing the "Start" button. Also make sure your "Run" switch is in the middle position (right handle, just above the Start button). If you still have trouble, it could be alot of things:
1. Have you "charged" your battery??? These scooters came with a plug-in battery charger. It plugs into a wall outlet, and the other end plugs into a special adapter attached to the battery. Usually plugging it in about 1X per month should suffice, overnight.
2. You may need to replace the Choke Bystarter Valve - it's RARE and EXPENSIVE!!! Here's a place to find it: OZ Cycle Salvage - (785) 242-0060. It only comes attached to the carburator and it's $350! But that's better than paying $3500 for a new scooter!
3. You may need to replace the "Stator/Pickup Coil." Depending on where exactly (what factory) your scooter was made in Japan, there are 3 different ones available. The only way to tell what you have is to remove the engine housing and look at it. They prices range from $129 to $189. This part functions as the Alternator, as well as providing the necessary charge to the starter (at least from what my mechanic told me). If your lights dim considerably when you come to a stop, this is most likely the problem.
4. You may simply need a new battery. Don't go with an acid filled one! Purchase a "Maintenance Free" battery. www.motorcyclebatteriesusa.com. Mine was $35.75 with Free Shipping and it works GREAT!
Other than that, I am very pleased with my scooter. It has about 9500 miles on it, and runs very well. I get about 54 miles per gallon (GREAT NEWS at this time)! I can also cruise with relative ease at 45-50mph. With a good backwind, I have hit 55, but never any better.
If you have any questions, please forward them to my email address - kenmartin@insightbb.com.
HAVE FUN!!!
  84 Honda Aero 125 Scooter E K 07/31/05 06:50AM
  Re: 84 Honda Aero 125 Scooter E K 07/31/05 06:51AM
  Re: 84 Honda Aero 125 Scooter Mike Lumbert 07/31/05 07:23AM
  $20.00 reward for a float - Read on spamhater 06/20/06 10:04PM
  Re: $20.00 reward for a float is over spamhater 06/22/06 07:19PM
  Re: 84 Honda Aero 125 Scooter E K 07/31/05 08:16AM
  Re: 84 Honda Aero 125 Scooter E K 08/01/05 04:13AM
  Re: 84 Honda Aero 125 Scooter Doug 07/24/07 03:16AM
  Re: 84 Honda Aero 125 Scooter TorontoBoy 07/31/05 09:43AM
  84 Honda Aero 125 Scooter Steamboat Aka J. R. Stevens 07/31/05 09:55AM
  Re: 84 Honda Aero 125 Scooter Shawn Mcdonald 07/31/05 11:29AM
  Re: 84 Honda Aero 125 Scooter E K 08/01/05 04:08AM
  Re: 84 Honda Aero 125 Scooter Shawn Mcdonald 08/02/05 10:35AM
  84 Honda Aero 125 Scooter Dave Mcgarry 08/01/05 01:07PM
  Re: 84 Honda Aero 125 Scooter E K 08/02/05 01:36AM
  Re: 84 Honda Aero 125 Scooter Dave Mcgarry 08/02/05 01:45AM
  Re: 84 Honda Aero 125 Scooter bob125cc 08/06/09 01:41AM
  Re: 84 Honda Aero 125 Scooter Bruce Rose 08/14/05 10:10PM
  Re: 84 Honda Aero 125 Scooter E K 08/16/05 08:53AM
  Re: 84 Honda Aero 125 Scooter scott 09/27/05 01:57PM
  Re: 84 Honda Aero 125 Scooter Brian Hanson 10/04/05 05:04PM
  Re: 84 Honda Aero 125 Scooter gilbert 11/09/08 02:27AM
  Re: 84 Honda Aero 125 Scooter gilbert 11/09/08 02:33AM
  Re: 84 Honda Aero 125 Scooter thomas 10/01/05 12:09PM
  84 Honda Aero 125 Scooter Brian Hanson 10/04/05 05:07PM
  Re: 84 Honda Aero 125 Scooter Ken Martin 10/05/05 07:09PM
  Document with Aero 125 info E K 10/06/05 04:27AM
  Honda Aero 125 GOODIES E K 10/06/05 04:15AM
  Here is the Wiring Diagram E K 10/06/05 04:19AM
  Here is a pic of Air box area E K 10/06/05 04:21AM
  Pic of Battery compartment area E K 10/06/05 04:22AM
  Close up Pic of Battery compartment area E K 10/06/05 04:23AM
  Pic of right side of Aero E K 10/06/05 04:24AM
  Pic of the carb E K 10/06/05 04:25AM
  Document with Info E K 10/06/05 04:40AM
  Carb & bystarter info document E K 10/06/05 04:44AM
  bump E K 10/13/05 02:06AM
  Parts for 125 areo Tommy 10/15/05 07:11PM
  Re: Parts for 125 areo E K 10/15/05 11:54PM
  Re: Parts for 125 areo E K 10/19/05 05:04AM
  Re: Parts for 125 areo E K 11/06/05 03:18AM
  Re: Parts for 125 areo Steamboat Aka J. R. Stevens 11/06/05 08:30AM
  Re: Parts for 125 areo E K 11/13/05 10:35PM
  Re: Carb & bystarter info document david 09/05/07 07:37AM
  Re: Carb & bystarter info document Duly_Noted 07/31/08 11:41AM
  Re: Carb & bystarter info document bob125cc 08/29/09 12:32AM
  Re: Pic of the carb Colinswoop . 11/07/05 12:30PM
  Re: Pic of the carb E K 11/13/05 10:37PM
  P.S. The setup of manifold E K 11/13/05 10:42PM
  Re: P.S. The setup of manifold Colinswoop . 11/16/05 02:18AM
  Re: P.S. The setup of manifold E K 11/17/05 01:54PM
  Re: Pic of the carb kawika 11/17/05 11:57PM
  Re: Pic of Battery compartment area Pfwestwood 07/25/06 12:32PM
  Re: Pic of Battery compartment area Steamboat Aka J. R. Stevens 07/25/06 03:10PM
  Re: 84 Honda Aero 125 Scooter Doug 07/24/07 03:17AM
  Re: 84 Honda Aero 125 Scooter John Joedicke 07/25/07 08:16AM
  Re: 84 Honda Aero 125 Scooter bob125cc 08/29/09 12:23AM
  Re: Carb & bystarter info document jon 09/05/07 09:50AM
  Re: Carb & bystarter info document Doug Gallagher 09/05/07 12:52PM
  bystarter missing needle tink409 09/06/07 10:15PM
  Re: bystarter missing needle bob125cc 08/29/09 12:42AM
  Re: 84 Honda Aero 125 Scooter timylvrs 01/29/08 05:48PM
  Re: 84 Honda Aero 125 Scooter maciek 01/29/08 06:41PM
  Re: 84 Honda Aero 125 Scooter clay 05/18/08 06:11PM
  Re: 84 Honda Aero 125 Scooter keller_stephen 05/18/08 11:34PM
  Re: 84 Honda Aero 125 Scooter Marie 08/06/08 12:38AM
  Re: 84 Honda Aero 125 Scooter bob125cc 08/06/09 01:48AM
  Re: 84 Honda Aero 125 Scooter jon 05/18/08 06:14PM
  Re: 84 Honda Aero 125 Scooter clay 05/28/08 01:23AM
  Re: 84 Honda Aero 125 Scooter nate 05/28/08 05:59PM
  Re: 84 Honda Aero 125 Scooter Joseph 05/28/08 11:41PM
  Re: 84 Honda Aero 125 Scooter Dr. Rockzo 08/06/09 12:46PM
  Re: 84 Honda Aero 125 Scooter maciek 08/07/09 01:09AM
  Re: 84 Honda Aero 125 Scooter Barry 08/07/09 09:47AM
  Re: 84 Honda Aero 125 Scooter brian hammerhead 11/21/09 10:06AM
  Re: 84 Honda Aero 125 Scooter brian hammerhead 11/21/09 10:13AM
  Parts for your Aero 125 khy 08/04/10 07:12PM
  Parting out my 84 Aero 125 khy 08/04/10 07:20PM
Click here to login.
