Forums / Moped Repair
Checking oil on Tomos Sprint?
Nero () — Apr 05, 2005 08:45PM
How do I check the oil level on a 2003 Tomos Sprint?
I laid the moped on the side and put oil in the "oil checking bore hole".
I rode for a few minutes and then checked the oil by removing the side casing screw (oil checking bore hole).
Oil (Dexron III) came pouring out of the hole.
I hurried up and put back in the screw.
Was this how I was suppose to check the oil?
Should I have let more Dexron III drain out?
Thanks.
Nero; doing spring mainenance.
  Checking oil on Tomos Sprint? Nero 04/05/05 08:45PM
  Re: Checking oil on Tomos Sprint? Jon Smythe 04/07/05 01:37AM
  Re: Checking oil on Tomos Sprint? Bainesworth - 04/08/05 09:28AM
Click here to login.
