Forums / Moped Repair
Re: clutch slipped/broken?
Perry Manessis (perrym) — Apr 07, 2005 05:25PM
Don't be scared to tinker with it. It's a simple little moped, it's not like replacing a torque converter in a car's tranny. Fist, drain the tranny fluid, then pull the tranny cover off, it's only a few bolts. Look in through the peep holes of the outter clutch drum and see what's up with the clutches. There should be 2 sets, one for first gear and another set for second. Another thing that could have happend, is the outter drum assembly worked it's way loose. It's happend before.
  clutch slipped/broken? Matt Erdman 04/06/05 06:28PM
  Re: clutch slipped/broken? Matt Erdman 04/06/05 06:30PM
  Re: clutch slipped/broken? Matt Erdman 04/06/05 08:51PM
  Re: clutch slipped/broken? Perry Manessis 04/07/05 03:12PM
  Re: clutch slipped/broken? Matt Erdman 04/07/05 05:08PM
  Re: clutch slipped/broken? Perry Manessis 04/07/05 05:25PM
  Re: clutch slipped/broken? Matt Erdman 04/07/05 09:01PM
  Re: clutch slipped/broken? Perry Manessis 04/07/05 10:55PM
  Re: clutch slipped/broken? Matt Erdman 04/09/05 10:01PM
Click here to login.
