Forums / Moped Repair
how to test ignition coil
Ben Elsewhere (uglyfuzz) — Dec 23, 2004 10:00PM
Does anyone have a clue how to test an ignition coil to see if it is functional? i.e. with a mutlimeter.... Do they normally fail?
I'm still trying to troubleshoot the ignition system on my Indian. The plug is good, the magneto is putting out juice, because I can beep the horn I hardwired to the battery.
It must be one of these, correct?
Wiring Problem
Condensor
*Ignition Coil
Which should I suspect first, which is the most common failure?
The 'ped failed all of a sudden during a 10 mile-ish ride, if that's a helpful clue.
Thanks a lot in advance!
--Ben
Click here to login.
