FS: PA50, Motobecane, Morini and Minarelli parts
Ok more stuff and some old stuff. Make offers please.
PA50I Frame, forks, front wheel and front brake cable.
PA50 Random wiring harness. All the connections look good.
PA50 Headlight bucket. One of the tabs is broke an the other is cracked. The speedo seems good and has wiring for the speedo light.
PA50I Carb. Needs to be cleaned.
PA50 seat in good condition. Has a small tear on the bottom front but you can't see it when it's installed.
PA50I subframe. Has the kickstand and spring, also the airfilter is in there.
PA50 rear shelf.
PA50I cylinder, dirty but has a good bore.
Gurtner carb AR2.10 off from a Motobecane 50. Bike ran with this carb on it.
MO1 internal gear set and stock Morini clutch
Morini BRN two shoe clutch
Morini Pedal shafts
Minarelli V1 38.7mm stock cylinder
PA50 rear shelf.
Morini Pedal shafts
