Forums / Buy + Sell
Freshly ported/rebuilt vespa engine - $100
Graham Motzing ( grahammotzing) — Feb 09, 2010 10:56AM
Is this worth $100? I'm not sure, but I've got at least that much time into it, and I could use some cash. It is ported as radical you can get with the stock case, including a lot of proprietary magic.
Its already pretty well opened up for any 43mm kits. I'll throw in a High Compression head.
It has about 10 miles on it. Ran perfectly. I'm looking at picking up another project bike.
I'll install a kit, test and tune it for additional cost, if you would like to buy a fully set up motor.
Bottom end, ignition, flywheel, cylinder studs, all included. Carb and HC head also available at additional cost.
email motzingg at gmail dot com
Click here to login.
