Re: what to use to flush a case? chris MWH?
Diesel will be fine. I usually use Brake cleaner to flush it out. Having the engine off of the bike will make the flush much easier. Also make sure that you pre lubricate the Crank bearings / seals and the lower connecting rod with 2 cycle oil before installing the top end.
(someone should invent an aluminium magnet)
Chris MWH
Chris MWH
| Subject | Written By | Posted |
