Forums / General Moped Discussion
Re: top tank on puch maxi
mark (tomos_93tt) — Jan 05, 2010 09:32AM
The Targa tank looks a little odd on a Maxi at first, but you soon get used to it.
I welded a cross bar to the frame and made a bracket to hold the front rubber tank mounting bushings to the cross bar. The rear mounting tab on the tank was reinforced and bolted to the cross bar. I cut off the extra "fins" that run along the bottom of the tank sides and removed the mounting tabs for the Tomos plastics to clean up the looks. The Targa tank works well on a Maxi as it is designed to overlap the existing in-frame tank.
The advantages to doing this include: having a larger easier to access tank, having something to clamp your knees to for stability, and extending the life of a leaky frame.
  top tank on puch maxi Joe 01/04/10 09:41PM
  Re: top tank on puch maxi ( ͡° ͜ʖ ͡° ) 01/04/10 09:50PM
  Re: top tank on puch maxi mark 01/05/10 09:32AM
  Re: top tank on puch maxi Chris Rice 01/05/10 01:16PM
  Re: top tank on puch maxi Joe 01/05/10 07:57PM
  Re: top tank on puch maxi Revvin' Kevin 01/05/10 08:22PM
  Re: top tank on puch maxi Ian 01/05/10 09:44AM
  Re: top tank on puch maxi small bore 01/05/10 11:08AM
  Re: top tank on puch maxi Marco Last Name 01/05/10 11:52AM
  Re: top tank on puch maxi Joe 01/05/10 09:02PM
  Re: top tank on puch maxi Tiger Matt 01/05/10 12:00PM
  Re: top tank on puch maxi Tiger Matt 01/05/10 12:03PM
  Re: top tank on puch maxi FlyByNight Taylor 01/05/10 01:10PM
  Re: top tank on puch maxi ( ͡° ͜ʖ ͡° ) 01/05/10 03:53PM
  Re: top tank on puch maxi Tiger Matt 01/05/10 03:57PM
  Re: top tank on puch maxi mark 01/05/10 05:01PM
  Re: top tank on puch maxi Dale Myers 06/08/11 04:01PM
  Re: top tank on puch maxi Tiger Matt 01/05/10 05:12PM
  Re: top tank on puch maxi Will campeona del mundo . 01/05/10 06:24PM
  Re: top tank on puch maxi ( ͡° ͜ʖ ͡° ) 01/05/10 08:01PM
  Re: top tank on puch maxi TSluss 01/05/10 09:04PM
  Re: top tank on puch maxi Sunset Paul 01/05/10 09:42PM
  Re: top tank on puch maxi revdub . 01/05/10 10:18PM
  Re: top tank on puch maxi Seth Bedwell 01/05/10 10:21PM
  Re: top tank on puch maxi Jeremy Shay 01/06/10 01:25AM
  Re: top tank on puch maxi yuckytori 01/07/10 04:48AM
  Re: top tank on puch maxi Joe 01/17/10 03:57PM
  Re: top tank on puch maxi Tiger Matt 01/17/10 04:21PM
  Re: top tank on puch maxi Al . 01/17/10 04:23PM
  Re: top tank on puch maxi Tri-ped Dave 01/17/10 04:44PM
  Re: top tank on puch maxi ( ͡° ͜ʖ ͡° ) 01/17/10 04:48PM
  Re: top tank on puch maxi chrishmaiel 01/17/10 05:03PM
  Re: top tank on puch maxi andrewhed 01/17/10 06:48PM
  Re: top tank on puch maxi TobiWan 01/17/10 07:54PM
  Re: top tank on puch maxi Ponyboy MP 01/17/10 10:13PM
  Re: top tank on puch maxi Uphill Harvey 01/17/10 11:47PM
  Re: top tank on puch maxi mark 01/18/10 11:45AM
  Re: top tank on puch maxi K Olena 11/03/11 10:06AM
Click here to login.
