Forums / General Moped Discussion
I built a time capsule Into my Hobbit
cheetahchrome . (cheetahchrome) — Nov 27, 2009 02:26AM
It all actually started as a subframe modification since I was having a lot of trouble tuning my 21mm Dellorto.
Fed up with constantly undoing the rear shock bolts and jacking the rear of the frame up so I could
unbolt the intake and fish it out with the carb attached,I decided to cut off the top of my subframe air box.
I started the process the same way I've done many times by placing a 2x4 under the kickstand then blocking the front wheel so the front of the bike
doesn't try to roll away and topple over when I jack up the rear section
Remove the lower rear shock bolts, and raise up on the rear of the frame till you can slide a wood slat inbetween
the top of the rear tire and the fender support brace. I also like to remove the fuel line so it doesn't get pinched.
  I built a time capsule Into my Hobbit cheetahchrome . 11/27/09 02:26AM
  Re: I built a time capsule Into my Hobbit cheetahchrome . 11/27/09 04:31AM
  Re: I built a time capsule Into my Hobbit Nick 11/27/09 09:41AM
  Re: I built a time capsule Into my Hobbit - rwc - 11/27/09 10:09AM
  Re: I built a time capsule Into my Hobbit m6onz5a 11/27/09 10:25AM
  Re: I built a time capsule Into my Hobbit doppelkolben 11/27/09 11:19AM
  Re: I built a time capsule Into my Hobbit [[ Linda ]] 11/27/09 12:57PM
  Re: I built a time capsule Into my Hobbit naz 11/27/09 01:12PM
  Re: I built a time capsule Into my Hobbit ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/27/09 01:24PM
  Re: I built a time capsule Into my Hobbit FlyByNight Taylor 11/27/09 01:31PM
  Re: I built a time capsule Into my Hobbit peter 11/27/09 02:18PM
  Re: I built a time capsule Into my Hobbit Southern Dandy JCams 11/27/09 08:38PM
  Re: I built a time capsule Into my Hobbit [[ Linda ]] 11/28/09 04:26AM
  Re: I built a time capsule Into my Hobbit Tony Gumble 11/28/09 06:20AM
  Re: I built a time capsule Into my Hobbit Eoban 11/30/09 03:39PM
  Re: I built a time capsule Into my Hobbit Arms Swoop 11/30/09 03:51PM
  Re: I built a time capsule Into my Hobbit Graham Motzing 12/16/09 04:08PM
  Re: I built a time capsule Into my Hobbit Anno 05/06/10 03:52AM
  Re: I built a time capsule Into my Hobbit Nick 05/06/10 07:02AM
  Re: I built a time capsule Into my Hobbit [[ Linda ]] 05/06/10 10:39AM
  Re: I built a time capsule Into my Hobbit brooks rayman 06/04/10 11:33PM
Click here to login.
