Re: Would you buy this Magnum?
First off, go buy it now. As soon as you see any Magnum somewhat close to you at that price, take everything you do not need to the pawn shop if you do not have enough money and buy it. If that frame has a title, you should be able to get $200 for the frame and just the frame, no fork , no swing arm. The swing arm is worth $60. That is worth $200 if it did not have an engine. People in Cali wish they could get a deal like that, or anywhere else far as that goes.The worst thing you have to worry about is the seals in a one speed engine and on the two speed you also have the pucks in the transmission to worry about. You can get another engine if that engine is not easy for you to fix. You may not get another chance at a $200 Magnum, or any Magnum close to you.
