Forums / General Moped Discussion
12v Easy Halogen Conversion (With Pics)
Jeremy (D) Bandit ( jeremyd) — Nov 07, 2009 03:03PM
I thought I would pass this along. It seems to have worked out really well for me. Remember, this is for a 12v setup. Also, this fix works best with stock bulb mounts with the little metal piece that holds things into place. Read on...
Needed: (1) 9006 Halogen Bulb $6-$14, (1) 9006 Plug $2-$3 at any auto parts store, and electrical tape.
Tools: Dremel with cut off wheel and simple grinding tool.
First, buy a 9006 halogen bulb ($6 at harbor freight) and plug (maybe $3). You need the bulb with a 45 degree bend in the plug portion like this:
Here's another pic:
You also need a plug that fits this bulb:
Start with the part of your headlight that your bulb plugs into, like this (stock puch bulb mount):
I used a bullet headlight, so mine looks a little different than the one above. The key to this conversion is to dremel and cut your plastic bulb mount so that all metal and extra plastic is removed. The idea is that you are going to use the stock bulb mount to mount your new halogen bulb and keep it in place. You will want to cut and dremel out just enough material so that your bulb can fit into the stock one and all sits in place well. This is VERY important, because if these hot hot halogen bulbs get loose in your housing, you will get this (no good):
So anyway, after your cutting and dremel work, you want to end up with something like this:
Next, plug your halogen 9006 into it like so:
Now mount it to your headlight. If you have a metal piece that holds your stock bulb in, you're in luck. If not, you will have to find a good way to keep the bulb in place, such as crazyglue+baking soda. But this fix is for those with the little metal piece. See how beautifully it fits!:
Now tape it up real good:
Insert the plug into the back of the halogen:
Wire it up, yo!! One wire goes to the ground, the other goes to the stator/voltage regulator. You end up with something like this:
These halogens are super bright (55w - like daylight) and they do not burn out. I have a non-working voltage regulator, a 12 volt CDI setup, and I can't get the bulb to burn... no matter how high I rev! Hope this helps someone. Peace out.
  12v Easy Halogen Conversion (With Pics) Jeremy (D) Bandit 11/07/09 03:03PM
  Re: 12v Easy Halogen Conversion (With Pics) Seth Bedwell 11/07/09 03:18PM
  Re: 12v Easy Halogen Conversion (With Pics) teddybear 11/07/09 03:58PM
  Re: 12v Easy Halogen Conversion (With Pics) Jeremy (D) Bandit 11/07/09 04:07PM
  Re: 12v Easy Halogen Conversion (With Pics) Quinn 11/07/09 04:10PM
  Re: 12v Easy Halogen Conversion (With Pics) Martin 11/07/09 05:24PM
  Re: 12v Easy Halogen Conversion (With Pics) Right Said Jed 11/07/09 05:43PM
  Re: 12v Easy Halogen Conversion (With Pics) 47steve 11/09/09 07:34PM
  Re: 12v Easy Halogen Conversion (With Pics) Weak-Ends Tj 11/09/09 07:44PM
  Re: 12v Easy Halogen Conversion (With Pics) Jeremy (D) Bandit 11/07/09 05:43PM
  Re: 12v Easy Halogen Conversion (With Pics) Godzilla 11/07/09 06:36PM
  Re: 12v Easy Halogen Conversion (With Pics) teddybear 11/08/09 11:07AM
  Re: 12v Easy Halogen Conversion (With Pics) Chris 09/11/10 11:16AM
  Re: 12v Easy Halogen Conversion (With Pics) deaneky 11/07/09 07:50PM
  Re: 12v Easy Halogen Conversion (With Pics) peter 11/07/09 08:27PM
  Re: 12v Easy Halogen Conversion (With Pics) Jeremy (D) Bandit 11/07/09 08:52PM
  Re: 12v Easy Halogen Conversion (With Pics) tomtom 11/07/09 09:59PM
  Re: 12v Easy Halogen Conversion (With Pics) Jeremy Shay 11/08/09 03:40AM
  Re: 12v Easy Halogen Conversion (With Pics) vic 11/08/09 04:00AM
  Re: 12v Easy Halogen Conversion (With Pics) Mo Peds 11/08/09 10:18AM
  Re: 12v Easy Halogen Conversion (With Pics) teddybear 11/08/09 11:27AM
  Re: 12v Easy Halogen Conversion (With Pics) Weak-Ends Tj 11/08/09 11:40AM
  Re: 12v Easy Halogen Conversion (With Pics) teddybear 11/08/09 11:58AM
  Re: 12v Easy Halogen Conversion (With Pics) Nate Bandit 11/08/09 11:50AM
  H3 12v 55W High/Low in stock Tomos shell Weak-Ends Tj 11/08/09 01:46PM
  Re: H3 12v 55W High/Low in stock Tomos shell Jeremy (D) Bandit 11/08/09 02:02PM
  Re: H3 12v 55W High/Low in stock Tomos shell RingringBANG ! 11/08/09 04:08PM
  Re: H3 12v 55W High/Low in stock Tomos shell Weak-Ends Tj 11/08/09 04:17PM
  Re: H3 12v 55W High/Low in stock Tomos shell RingringBANG ! 11/08/09 04:23PM
  Re: H3 12v 55W High/Low in stock Tomos shell Southern Dandy JCams 11/08/09 08:01PM
  Re: 12v Easy Halogen Conversion (With Pics) Weak-Ends Tj 11/08/09 08:11PM
  Re: 12v Easy Halogen Conversion (With Pics) Weak-Ends Tj 11/08/09 08:14PM
  Re: 12v Easy Halogen Conversion (With Pics) Weak-Ends Tj 11/08/09 08:25PM
  Re: H3 12v 55W High/Low in stock Tomos shell Jeremy (D) Bandit 11/08/09 08:13PM
  Re: H3 12v 55W High/Low in stock Tomos shell RingringBANG ! 11/08/09 09:23PM
  Re: H3 12v 55W High/Low in stock Tomos shell Weak-Ends Tj 11/08/09 09:49PM
  Re: H3 12v 55W High/Low in stock Tomos shell spencer 11/08/09 09:29PM
  Re: H3 12v 55W High/Low in stock Tomos shell Marco Last Name 11/09/09 09:39AM
  Re: H3 12v 55W High/Low in stock Tomos shell Graham Motzing 11/09/09 06:32PM
  Re: H3 12v 55W High/Low in stock Tomos shell Ismael . 11/09/09 06:38PM
  Re: 12v Easy Halogen Conversion (With Pics) RingringBANG ! 11/09/09 07:53PM
  Re: 12v Easy Halogen Conversion (With Pics) woodbang ! 08/17/10 08:26PM
  Re: 12v Easy Halogen Conversion (With Pics) Weak-Ends Tj 11/16/09 09:07PM
  Re: 12v Easy Halogen Conversion (With Pics) The Hebrew Hammer 12/21/09 02:42PM
  Re: 12v Easy Halogen Conversion (With Pics) tomtomtomtomtomtom 12/21/09 05:43PM
  Re: 12v Easy Halogen Conversion (With Pics) tomtomtomtomtomtom 12/21/09 05:48PM
  Re: 12v Easy Halogen Conversion (With Pics) Chris Paz 12/21/09 06:04PM
  Re: 12v Easy Halogen Conversion (With Pics) Jeremy (D) Bandit 12/21/09 09:18PM
  Re: 12v Easy Halogen Conversion (With Pics) J D 12/22/09 03:27PM
  Re: 12v Easy Halogen Conversion (With Pics) Ace Levenberg 12/22/09 03:30PM
  Re: 12v Easy Halogen Conversion (With Pics) Gabe Bandit 12/22/09 03:38PM
  Re: 12v Easy Halogen Conversion (With Pics) Gabe Bandit 12/22/09 03:41PM
  Re: 12v Easy Halogen Conversion (With Pics) J D 12/22/09 06:00PM
  Re: 12v Easy Halogen Conversion (With Pics) Gabe Bandit 12/22/09 06:16PM
  Re: 12v Easy Halogen Conversion (With Pics) J D 12/22/09 06:22PM
  Re: 12v Easy Halogen Conversion (With Pics) cam 05/20/10 03:37PM
  Re: 12v Easy Halogen Conversion (With Pics) craig dueck 12/22/09 11:34PM
  Re: 12v Easy Halogen Conversion (With Pics) - Chad 12/22/09 11:49PM
  Re: 12v Easy Halogen Conversion (With Pics) Gabe Bandit 12/23/09 01:16AM
  Re: 12v Easy Halogen Conversion (With Pics) WillD SWOOP 05/20/10 03:41PM
  Re: 12v Easy Halogen Conversion (With Pics) kkkbills 05/20/10 04:39PM
  Re: 12v Easy Halogen Conversion (With Pics) Jeremy (D) Bandit 05/20/10 04:49PM
  Re: 12v Easy Halogen Conversion (With Pics) Flagrant - 05/20/10 05:48PM
  Re: 12v Easy Halogen Conversion (With Pics) Crazy Wayne Treats Rock's 05/20/10 07:41PM
  Re: 12v Easy Halogen Conversion (With Pics) Crazy Wayne Treats Rock's 05/20/10 07:45PM
  Re: 12v Easy Halogen Conversion (With Pics) Justin 05/21/10 06:09AM
  Re: 12v Easy Halogen Conversion (With Pics) Justin 05/21/10 06:12AM
  Re: 12v Easy Halogen Conversion (With Pics) Troy 05/21/10 01:49PM
  Re: 12v Easy Halogen Conversion (With Pics) D 05/21/10 02:52PM
  Re: 12v Easy Halogen Conversion (With Pics) Josh -+:| 09/11/10 11:26AM
  Re: 12v Easy Halogen Conversion (With Pics) The Hebrew Hammer 09/11/10 11:34AM
  Re: 12v Easy Halogen Conversion (With Pics) Slow Goer Chad 07/25/11 02:38AM
  Re: 12v Easy Halogen Conversion (With Pics) Jeremy (D) Bandit 07/25/11 05:43PM
  Re: 12v Easy Halogen Conversion (With Pics) ¿Chris? _uhs_ 07/25/11 07:14PM
Click here to login.
