Forums / General Moped Discussion
Re: Most durable moped/engine
Tate (madtownmick) — Nov 06, 2009 09:16PM
I guess its not a moped but if I had to a bet my life on a moped getting me somewhere, it would be a honda express.
They refuse to stop running. They also run roughly the same and usually don't "sorta run". A lot of hobbits sorta run, in the way that they start but they wont idle, or they will idle but they don't variate, or they variate but the pedals are broken, or the electrical shit gives problems or or or. The actual engine on the hobbit is almost the same as an express, but the other stuff that makes it better, i.e. the variators and pedals are the things that give out.
As far as actual mopeds, I would say the puch E50. E50s will run with 1/2 of one ring, they will run on ancient gas, they will run after being seized a dozen times, they will run with bearings that sound like a garbage disposal, and they don't have any fatal and or endemic electrical issues. Also the frames are tough as hell. I have never seen a kinked maxi frame. Only problem is the internal gas tank. That is the only major strike against it. I have never owned a pinto or a free spirit or a murray or any of the external tank E50s, so I donno how those frames are.
Tomos A35s are good but they have clutch issues pretty often. That is kind of their weak point. Also where the tomos body itself is pretty tough, the materials and build quality could be a little better. The plastics are fragile, the paint chips/flakes easily, they rust up if you don't keep them inside. They are good, just not the best.
I would have to say the worst by far is the Motobecane. The frame itself is ok, and it feels solid when you rid it, but there is always some bullshit problem or riddle you can't solve or part you can't get off. A lot of mopeds wont run because there is something wrong with them, no spark, no mixture, no compression. A motobecane will not run or stop running just because it feels like it. Once I spent all morning fixing a motobecane and I finally got it running right. I went to eat lunch and when I came back it had a new problem and never ran again. True story.
  Most durable moped/engine Marco Last Name 11/06/09 01:57AM
  Re: Most durable moped/engine SUNSET vanilla thunder-brokane 11/06/09 02:07AM
  Re: Most durable moped/engine Tony 11/06/09 02:32AM
  Re: Most durable moped/engine lord of chaos666 11/06/09 03:04AM
  Re: Most durable moped/engine ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/06/09 03:54AM
  Re: Most durable moped/engine SUNSET vanilla thunder-brokane 11/06/09 04:00AM
  Re: Most durable moped/engine zeke 11/06/09 04:05AM
  Re: Most durable moped/engine Los Dean 11/06/09 04:08AM
  Re: Most durable moped/engine Chris Rice 11/06/09 03:19PM
  Re: Most durable moped/engine mopedjay 11/06/09 04:29PM
  Re: Most durable moped/engine orange JUICE 11/06/09 09:46AM
  Re: Most durable moped/engine jOHNNYdOUBE 11/06/09 10:35AM
  Re: Most durable moped/engine Robert Rosselit 11/06/09 10:37AM
  Re: Most durable moped/engine doppelkolben 11/06/09 10:45AM
  Re: Most durable moped/engine orange JUICE 11/06/09 10:59AM
  Re: Most durable moped/engine keller_stephen 11/06/09 09:34PM
  Re: Most durable moped/engine orange JUICE 11/06/09 11:21AM
  Re: Most durable moped/engine mopedjay 11/06/09 12:03PM
  Re: Most durable moped/engine keller_stephen 11/06/09 09:38PM
  Re: Most durable moped/engine chris†opher k 11/06/09 12:27PM
  Re: Most durable moped/engine Lance Campeau 11/06/09 01:59PM
  Re: Most durable moped/engine Rob @t ATTN! Burrito 11/06/09 02:40PM
  Re: Most durable moped/engine Tri-ped Dave 11/06/09 02:47PM
  Re: Most durable moped/engine mopedjay 11/06/09 03:20PM
  Re: Most durable moped/engine Robert Rosselit 11/07/09 12:39PM
  Re: Most durable moped/engine SUNSET motobrokane 11/06/09 04:38PM
  Re: Most durable moped/engine keller_stephen 11/06/09 09:44PM
  Re: Most durable moped/engine Bret Hoffman 11/06/09 04:43PM
  Re: Most durable moped/engine mopedjay 11/06/09 04:52PM
  Re: Most durable moped/engine Todd 11/06/09 04:48PM
  Re: Most durable moped/engine Marco Last Name 11/06/09 06:07PM
  Re: Most durable moped/engine Oleg Kostoglotov 11/06/09 08:37PM
  Re: Most durable moped/engine Tate 11/06/09 09:16PM
  Re: Most durable moped/engine jOHNNYdOUBE 11/06/09 09:47PM
  Re: Most durable moped/engine keller_stephen 11/06/09 10:04PM
  Re: Most durable moped/engine tomtom 11/06/09 10:47PM
  Re: Most durable moped/engine keller_stephen 11/06/09 11:29PM
  Re: Most durable moped/engine ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/07/09 04:14AM
  Re: Most durable moped/engine Tri-ped Dave 11/07/09 10:02AM
  Re: Most durable moped/engine zeke 11/07/09 10:42AM
  Re: Most durable moped/engine tomtom 11/07/09 10:14PM
  Re: Most durable moped/engine ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/07/09 11:48PM
  Re: Most durable moped/engine zeke 11/08/09 12:47AM
  Re: Most durable moped/engine patrick 11/08/09 06:22PM
  Re: Most durable moped/engine Seth Zaiser 11/08/09 06:03PM
  Re: Most durable moped/engine patrick 11/08/09 06:24PM
Click here to login.
