Idle mixture vs idle speed screw
Had a lot of questions about which is which on a Honda Express. So This is for those that don't know. Check out the picture. The pencil is pointing to the screw that adjusts the Throttle slide and therefore the idle speed. The screw slightly below and to the left is the mixture screw. The screw at the very bottom is the float bowl drain screw. This carb is from a 1978 Honda Express NC50.
| Subject | Written By | Posted |
