Forums / General Moped Discussion
Re: AR93
Ben Eberle (beneberle) — Oct 27, 2009 12:28PM
YES!!! This thread is AWESOME!
I've been thinking about getting one of those 93cc cylinders for my AR80 too, but I was told by the dude on Ebay that they're cast iron and weigh a ton....making shipping MAD expensive. Mine run so well right now that I'm happy to just go with what I've got.
Hey....can you explain why bump starting it would cause the timing to slip? I'm not really understanding that one. No points in these things. CDI only. I haven't really gone through the manual enough to see how the crank is configured on the starter and on the flywheel.
FYI - if you want to repaint that tank, use GMC red color coded spray paint # 5321. It's basically a perfect match.
I also talked with a few dudes at my local motorsports store and they said the same thing about the pipe. It's definitely good enough to rip hard (I mean...mine wheelies in first and 2nd gear if I'm not careful)...but top end could be improved if you just take out the baffle in the back. It'll obviously make it louder, but it'll give a boost on the top end. Mine runs at 68mph at 10.5k RPM. That's redline. I would absolutely regear that bitch with the big kit. You'll blow the tranny for sure at 13-15k RPM.
Awesome dude! This post is so rad! Keep the updates coming. Here's mine:
  AR93 pauld 10/26/09 12:38PM
  Re: AR93 De Rp 10/26/09 12:58PM
  Re: AR93 pauld 10/26/09 01:12PM
  Re: AR93 ineedmyjam 10/26/09 02:53PM
  Re: AR93 pauld 10/26/09 03:48PM
  Re: AR93 pauld 10/27/09 11:11AM
  Re: AR93 zeke 10/27/09 11:16AM
  Re: AR93 tweeder 10/27/09 11:23AM
  Re: AR93 tweeder 10/27/09 11:27AM
  Re: AR93 pauld 10/27/09 11:37AM
  Re: AR93 Ben Eberle 10/27/09 12:28PM
  Re: AR93 Ben Eberle 10/27/09 12:32PM
  Re: AR93 Colinswoop . 10/27/09 02:27PM
  Re: AR93 pauld 10/27/09 01:46PM
  Re: AR93 Mike Bartell 10/27/09 02:30PM
  Re: AR93 pauld 10/27/09 02:45PM
  Re: AR93 pauld 10/27/09 02:48PM
  Re: AR93 Colinswoop . 10/27/09 03:00PM
  Re: AR93 pauld 10/27/09 03:08PM
  Re: AR93 Ben 10/27/09 09:23PM
  Re: AR93 Sćŗάτçλmªřc • 10/27/09 10:42PM
  Re: AR93 pauld 10/27/09 11:52PM
  Re: AR93 Colinswoop . 10/28/09 10:04AM
  Re: AR93 tweeder 10/28/09 10:58AM
  Re: AR93 pauld 10/28/09 11:12AM
  Re: AR93 paul 10/28/09 07:39PM
  Re: AR93 Other Quinn 10/28/09 08:26PM
  Re: AR93 pauld 11/04/09 11:50AM
  Re: AR93 Bret Hoffman 11/04/09 01:42PM
  Re: AR93 Mike Bartell 11/04/09 02:17PM
  Re: AR93 Mike Bartell 11/04/09 02:20PM
  Re: AR93 Truckerick 11/04/09 03:03PM
  Re: AR93 pauld 11/04/09 03:30PM
  Re: AR93 pauld 11/05/09 04:07PM
  Re: AR93 Ben Eberle 11/05/09 06:31PM
  Re: AR93 pauld 11/06/09 10:55AM
  Re: AR93 Sćŗάτçλmªřc • 11/06/09 10:31PM
Click here to login.
