Forums / General Moped Discussion
AR93
pauld ( pauld) — Oct 26, 2009 12:38PM
I got an ar80 from dougler over the summer, and have been riding the hell out of it. The timing slipped at one point (flywheel completely came off the crankshaft) due to the kickstart being broken and having to bump start it. After i fixed this (incorrectly), it ran beautifully and would do 60mph no problem.
Last weekend i took it to bombourbon run and on the way back i blew a hole in my piston due to the timing being too advanced:
So i bought a 93cc kit for it from here expensive as hell, but parts for these are super rare and shipping from the UK was more than the kit itself. it arrived within a week and they sent me an extra piston, and gasket set along with a note that said they sent an extra one because they value their overseas customers. Rad dudes for sure.
I removed the old cylinder and cleaned out the crankcase of piston debris. I installed the new piston and cylinder but broke a ring in the process. Fortunately they sent that extra piston and i was able to use one of the other rings they sent me and was able to install the new kit successfully.
I removed the old airbox, tacho and speedo (they also broke on bombourbon) and i plan on building a mount for my gps unit where the instrumentation previously was housed. I also need to get a K&N style air filter, new jets, and some more plugs. And last but not least i need to fix the timing correctly so that i dont blow a hole in another piston. With the added torque and power from 13cc's i'm going to probably get a bigger front sprocket going from a 14 to a 16 tooth and perhaps a smaller rear if i think its necessary. i'm hoping to be able to do a comfortable 70mph cruising.
Thought i'd share. come check it out next time you're in cincinnati.
  AR93 pauld 10/26/09 12:38PM
  Re: AR93 De Rp 10/26/09 12:58PM
  Re: AR93 pauld 10/26/09 01:12PM
  Re: AR93 ineedmyjam 10/26/09 02:53PM
  Re: AR93 pauld 10/26/09 03:48PM
  Re: AR93 pauld 10/27/09 11:11AM
  Re: AR93 zeke 10/27/09 11:16AM
  Re: AR93 tweeder 10/27/09 11:23AM
  Re: AR93 tweeder 10/27/09 11:27AM
  Re: AR93 pauld 10/27/09 11:37AM
  Re: AR93 Ben Eberle 10/27/09 12:28PM
  Re: AR93 Ben Eberle 10/27/09 12:32PM
  Re: AR93 Colinswoop . 10/27/09 02:27PM
  Re: AR93 pauld 10/27/09 01:46PM
  Re: AR93 Mike Bartell 10/27/09 02:30PM
  Re: AR93 pauld 10/27/09 02:45PM
  Re: AR93 pauld 10/27/09 02:48PM
  Re: AR93 Colinswoop . 10/27/09 03:00PM
  Re: AR93 pauld 10/27/09 03:08PM
  Re: AR93 Ben 10/27/09 09:23PM
  Re: AR93 Sćŗάτçλmªřc • 10/27/09 10:42PM
  Re: AR93 pauld 10/27/09 11:52PM
  Re: AR93 Colinswoop . 10/28/09 10:04AM
  Re: AR93 tweeder 10/28/09 10:58AM
  Re: AR93 pauld 10/28/09 11:12AM
  Re: AR93 paul 10/28/09 07:39PM
  Re: AR93 Other Quinn 10/28/09 08:26PM
  Re: AR93 pauld 11/04/09 11:50AM
  Re: AR93 Bret Hoffman 11/04/09 01:42PM
  Re: AR93 Mike Bartell 11/04/09 02:17PM
  Re: AR93 Mike Bartell 11/04/09 02:20PM
  Re: AR93 Truckerick 11/04/09 03:03PM
  Re: AR93 pauld 11/04/09 03:30PM
  Re: AR93 pauld 11/05/09 04:07PM
  Re: AR93 Ben Eberle 11/05/09 06:31PM
  Re: AR93 pauld 11/06/09 10:55AM
  Re: AR93 Sćŗάτçλmªřc • 11/06/09 10:31PM
Click here to login.
