Forums / General Moped Discussion
tomos headlight mod, reconfigured
ryandurepo (ryandurepo) — Jul 03, 2009 11:35AM
ok everyone was saying to do the 9005 headlight mod right? well i found a 9145 is identical and comes in a nice holagen bulb, takes let power and is way brighter. now the big black hole right in front of you while riding sucks, so i got to thinking, its like a flashlight if you twist the end the bulb raises up and down and creates a hole or can center out, so what i did was cut off the tab(see attached photo) i highlighted the part to cut off in red. and pushed it all the way in and got rid of that big black spot! you may have to file it somewhat smooth but if found if you leave a few little like rough spots it was jam in there and be a tight fit.
  tomos headlight mod, reconfigured ryandurepo 07/03/09 11:35AM
  Re: tomos headlight mod, reconfigured dallas 07/03/09 05:07PM
  Re: tomos headlight mod, reconfigured Weak-Ends Tj 07/03/09 07:00PM
Click here to login.
